Need swaybar size
Discussion in 'Roadster 2008-2012' started by tesla-track-car, May 2, 2012.
Tags:
  1. tesla-track-car
    Sorry I posted this in the model S thread ..
    I need the sway bar size front and rear in inch or mm.
  2. tesla-track-car
    I need the roadster sway bars sizes ...
  3. tesla-track-car
  4. frequencydip
    frequencydip Sig 100 - #52
    Los Angeles
  5. TEG
    TEG Teslafanatic
    Thanks for finding that, frequencydip!
  6. NigelM
    NigelM Recovering Member
    Northern Virginia
    I got the new fans fitted today, the Ranger only showed me after I got home (was gone at work all day) as he was putting the cover back on, and that change required a new sway bar to make room for the larger fan unit. Sorry, didn't get the part number or size, but worth noting that there are at least 2 different ones.
    P.S. All my above comment is relevant for a 2.5
  7. TEG
    TEG Teslafanatic
    Another forum user posted this:
  8. tesla-track-car
    Thanks you guys. still need the size so that I can make it for cheaper........ I mean under $250
  9. tesla-track-car
    Thay don`t sell this set for the tesla retail
  10. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Next time I swap wheels I'll make a point of measuring the sway bars. Might be a few weeks though.
  11. frequencydip
    Los Angeles
    How do you plan to manufacture a replacement sway bar without a Tesla to size and test it on?
  12. tesla-track-car
    I think the sizes are 23.10mm & 25.9mm?
    but is the front one smaller?
  13. 7racer
    7racer Member
    is it the same as the Lotus Elise?
  14. Doug_G
    Ottawa, Canada
    Definitely not. Completely different car, completely different suspension setup.
  15. frequencydip
    Los Angeles
    Does anyone have part numbers for the suspension parts for the adjustable sport suspension?
    I would be looking for:
    Front dampers
    Rear Dampers
    Front Spring
    Rear Spring
    Front Swaybar
    Rear swaybar
    Its likely that the swaybars are custom but the dampers and springs should be off the shelf... Thanks if anyone can get these for me...
