SS,
That would require re-heat treating the material. You would also want to make very sure the parent material Tesla used in the extrusion was a "weldable" alloy. You might find the process more cost effective simply to have a water jet shop raw cut a set for you and then final machine the bores to your requirements. I went cheap on some of my water jet bits and did not core them to save on cycle time. I do not think the little bit of extra weight made a lick of difference.
It has been my experience that less toe in will improve wear at the expense of straight line stability. However, toe does not fix all the wear associated with over two degrees of negative camber.
