NEMA 14-30 Charger
Discussion in 'Model S: Battery & Charging' started by saurabhsingh, Jul 13, 2015.
  1. saurabhsingh
    saurabhsingh New Member
    Does anyone has extra Tesla Nema 14-30 charger? or know where I can buy one since Tesla is not making them anymore? If anyone has a spare they looking to see that be great?
  2. saurabhsingh
    Oh somehow missed it. Thanks for the quick reply. Also, if i get this do i need to adjust any amps or something in the car? I read in some threads that it was suggested to adjust car to 30amps
  3. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    Yes, you must dial down to 24 amps. The 30 amp circuit should not be used at 30 amps continuously.
    I recommend that you write with a Sharpie on the adapter, For EVSE use only, and 24 amp max. current.
  4. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    You will only be able to charge at 24A. Car won't let you adjust it higher.
  5. Lloyd
    San Luis Obispo, CA
    Not true, with this adapter he is using the 14-50 plug. It will default to 40 amps.
  6. dsm363
    Nevada
    Thanks. I was thinking about the Tesla adapter but you are right.
  7. saurabhsingh
    So i got the convertor, it works for about 10 - 15 mins then stops charging. i need to reset from main switch for it work again but it again goes off after 15 mins or so? Anyone else faced anything similar or have any suggestions?
    Thanks
    Saurabh
  8. randompersonx
    randompersonx Member
    Orlando, FL
    Did you make sure the car is charging at 24 Amps or less?
    If you are using a 50 Amp -> 30 Amp adapter, the car will try to pull 40 Amps out of an outlet rated for 24 Amp continuous.
  9. Cosmacelf
    Cosmacelf Well-Known Member
    San Diego
    If the "main switch" is turning off (which I take to mean the breaker in the electrical panel is tripping), then either you are generating too much heat, which usually means you are drawing too many amps (did you dial down the charging amps in the charging screen down to 24A?), OR the breaker could be old and wearing out.
    If you did dial down to 24A, and it trips, then I would dial it back further to 20A or 16A temporarily, and then replace the breaker. Make sure it is indeed a 30A breaker.
  10. mattmass
    mattmass Member
    Canada
    I experienced exactly this recently. 20A no problem. 24A pops the breaker within 10 mins every time. Having quite yet gotten around to replacing the breaker, but thanks for the suggestion, Cosmacelf!
  11. smilepak
    smilepak Active Member
    Eastvale, CA
  12. Ingineer
    Ingineer Electrical Engineer
    You can literally rip out the bottom pin on the Tesla 14-50 adapter. It's physically not connected to anything inside the adapter. Once you've done this, the adapter will fit 14-30 and 14-60 outlets in addition to the 14-50. Just remember to dial in 24A if you are using a 14-30.
  13. Oba
    Oba Member
    SoCal
    I would only recommend doing this with the 14-30 adapter, since you can safely plug it in the 14-50 or 14-60 outlet at 24 amps. Doing the reverse allows what happened up thread... overloading the circuit and popping the breaker (hopefully not burning something up).
  14. Ingineer
    Unfortunately Tesla no longer sells the 14-30 adapter. If they did, and you had one, there wouldn't be any point to this mod unless you were going to use a 14-60. Given that the car remembers amperages for each site, it's easy to set once to 24A and then not have to worry about it again. If you did forget, you'd pop the breaker in around a minute, which is not usually enough time for anything to get hot enough to worry about.
  15. Rocky_H
    Rocky_H Active Member
    Boise, ID
    That's the stupidest thing. That is probably the second most desired adapter, after the 5-20.
  16. randompersonx
    Orlando, FL
    I own: J1772, 14-50, 14-30, 10-30, 5-20, 5-15. I also own various home made extension cords / adapters.
    I use them in this order:
    14-50
    J1772
    Custom extension cord to 10-30 (with 14-50 plug, dialed down to 24A)
    5-15
    5-20
    I don't think I've ever used the 10-30 or 14-30 plugs ...
  17. MorrisonHiker
    MorrisonHiker S 100D 2019.16.2
    Colorado
    Wouldn't it be preferable to use 5-20 before 5-15?
  18. Brass Guy
    Brass Guy Member
    Holbrook, MA
    I think randompersonx meant by frequency, not by preference.
    I made a 10-50 adapter with a 6' stove plug. I used it a couple times, then filed down the N pin so it now also fits a 10-30 which I used over 2 weeks two different times so far.
    Oops, I missed this part...
  19. Ingineer
    Dryer outlets in the US almost exclusively use either a 10-30 (older house) or a 14-30 (newer). Over the years with the LEAF, I used the 10-30 the most, followed by the 14-x (I have the universal adapter so it fits in all 14 variants.)
