Not sure I saw anyone above make this point about the Wall Connector (WC) vs. a suitable outlet: Wall Connectors can fail. If they are hard-wired, you are stuck being unable to charge at home unless you have a suitable outlet and the appropriate adapter. It can be costly to disconnect and ship the WC back to Tesla. If it is in warranty and Tesla agrees to send out a technician, you may have to wait.
In my own case, when my WC failed, Tesla did send out an electrician, who tested it and replaced it. But I had to wait about 2 weeks for the appointment. In the meantime, i had to charge elsewhere, mainly at a nearby Supercharger.
After this experience, I posted that people who install WCs at home should consider wiring in a 240-volt outlet as well, as a contingency.
Are they not including the UMC or just the 14-50 adapter?
5-15 is a 110 volt?
14-50 is 220v 50 amp.
Maybe I've read this wrong? They dont want us doing a 220v, 50amp charge at home?
I ve read this too many times.
Excuse me, this looks like a profit item, i didnt see the cost?? $50 ?
So you pull out your UMC while getting it repaired. UMC's can fail too why are WC's exclusive to failing?
If your wall charger fails where are you plugging in your UMC, you yourself said they need to be hardwired and 14-50s are dumb. If my UMC fails on my 14-50 I take it to tesla and get a new one they have in stock the same day and continue about my life.So you pull out your UMC while getting it repaired. UMC's can fail too why are WC's exclusive to failing?
Adding a spare outlet isn't a bad idea, assuming it still meets code and includes GFCI. Sure, why not.
This is priceless, since you are the guy who ranted about how the UMC is unreliable, failure-prone garbage, so everyone should use a wall connector anyway. Thank you. That was hilarious.If I drop $83,000 on a new X they better throw in a god damn adapter.
I've yet to have a single Nuance trip with a boat load of AFCI I have. And the AFCI actually found one real problem.
This is literally the dumbest thing I've read on here in a while
That is good feedback, thanks. I am about to build a new house and I am wondering how much of an issue that might be.
The Internet is full of page after page after page of complaints about AFCI's and I have had friends that have had issues.
To be fair though, I am not sure how I would know the difference between a nuisance trip with AFCI and a real dangerous arcing condition. Can you explain how you troubleshot the one real problem you had?
This whole discussion reminds me of →
Has anyone tested if the Tesla 14-50 adapter tests the neutral with a traditional ground test like the normal ground? If not or if it is not connected as it is not used internally on an EVSE I want to cut mine off that way I can use it on both a 14-50 and a 14-30.
So confusing ! What happened to Tesla's plug in wall charger that was introduced in January 2019? I checked it out in late January and it was out of stock, now the link is a 404 not found! View attachment 400324 View attachment 400324 View attachment 400327 View attachment 400330 View attachment 400324
