It will be outside. The garage is far behind and cannot get regular sized vehicle inside. Will let the landlord know about the olev grant.You don't say whether your charging spot will be inside or outside. As others have said, EV charge points may require additional regulatory compliance, however, not all of these will apply if your vehicle is inside a covered garage, like an underground car park. Electrician should know best but not all are aware and some may suggest otherwise so always good to know what to expect in advance so it can be queried if required.
