I have no experience with that brand but if you are thinking of using an extension cord for every day use, especially at higher amperage, it's a bad idea. Tesla and the other manufacturers (GM for example) specifically state in the vehicle owner's manual that you should not use an extension cord to charge. I would only use an extension cord when camping, at a cabin, etc. on a temporary basis. Even then I would keep the extension cord as short as possible, lower the charging amperage at the first sign that the extension cord was getting warm (especially at the interconnections.)
There is a new product that is an extension cord for the Tesla charging cable. That could be a consideration but it is not inexpensive as each one has to be made to order.
Tesla extension cord Prices start at $299 for a 19 ft. Tesla charging cord extension rated for 32 amps. Seems like overkill since you only need a slightly longer charging cord for charging in your garage. Since you don't want to back the Tesla into your garage to charge I would investigate the cost of moving the placement of the 14-50 receptacle to the right side of the garage close to garage door. That would make it easy to reach the Tesla'a charging port with the Tesla charging cord, might even reach across to the left side of the garage if the Tesla was parked on the left. I would suggest that you get several different quotes for the charging circuit with the 14-50 receptacle.
