NEMA 14-50 outlet shows only 232v should I be concerned?
Discussion in 'Model S: Battery & Charging' started by ada43952, Aug 15, 2017.
  1. ada43952
    ada43952 Member
    Ohio
    As the title indicates, when I used a multimeter to check my outlet it only registers 232v. Is this normal? It's on a 50 amp breaker in a 200 amp box with 6 guage wire.
    Thanks
  2. Derek Kessler
    Derek Kessler Member
    Cincinnati
    Yeah, that's normal.
  3. Evoforce
    Evoforce Member
    Fountain Hills AZ
    I second that, totally normal.
  4. siucity
    siucity Button Pusher
    SF North Bay, CA
    Distance to outlet will make a difference.
  5. ada43952
    ada43952 Member
    Ohio
    Thank you! I knew there would be some fluctuations but I'm used to seeing them higher than the rated voltage.
  6. ada43952
    ada43952 Member
    Ohio
    The distance is just about 6 for from the box.
  7. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    Depends on what you started with. The delta of what you started with unloaded compared with voltage under load is more telling. Likely normal. 240 to 232 is fine.
  8. boaterva
    boaterva Supporting Member
    Northern Virginia, USA
    Yeah, a few percent drop is fine. It's more if you see variance as it's used or over time (like during the day as other loads are in use).
  9. David29
    David29 Active Member
    DEDHAM, MA
    I've seen variation from less than 230 to 241 or 242.
  10. gavine
    gavine Petrol Head turned EV Enthusiast
    Southern New Jersey
    I get 248 volts which forces my amps down to 47, presumably to not exceed the max kW of the charger.
  11. ShockOnT
    ShockOnT ⚡️⚡️⚡️⚡️⚡️
    Sydney
    Generally less that a 5% voltage drop at max load is acceptable.
    If you're getting 232V at zero load ;eg multimeter) then that's what you're getting from the grid.
    With a 6' (2m) run from your meter box you should get very little voltage drop at load, unless the wiring gauge is too thin.
    I have a 40m (120') run from my meterbox to garage (curse it) so can only charge at 25A 240V on a single phase HPWC that could do up to 40A. About 7kW.
    I've added a 32A three phase 5 pin plug near the meter box which I can use with an adapter to give 12kW just in case I ever need faster speed.
  12. ada43952
    ada43952 Member
    Ohio
    Well, I got my S85 today and got to test it and it's working perfectly.
  13. Derek Kessler
    Cincinnati
    Congratulations!
