NEMA 14-50 Plug Install Price
Quickstart88
239
94
Orange County
Just had a 75 foot run of wire done and install of a 60amp breaker with the NEMA 14-50 plug for charging. Paid $295 for labor and material. I thought that was a very reasonable price. Just getting opinions of others what you paid if you ran the same type connections.
Most home are 100 amp breaker panel. Careful. Putting a 60 amps breaker leaving just 40 amps free to use for your other appliance can fried your entire panel.
Quickstart88
239
94
Orange County
You can’t use a 60A breaker with a NEMA 14-50 outlet. It’s dangerous. No wonder your installation was so cheap. I bet he wasn’t a licensed electrician, was he?
Yup I did my homework. Nema 14-50 needs to be on a 50 amps. Also #6 wire. Don't burn your home down. Only Mid and East cost folks has 200 amps panel. Luck folks...
Quickstart88
239
94
Orange County
80% of 60amps = 48 amps.....48 amps is the max he'll be able to run continuously without the breaker tripping.
Does it not build up at 60 amps and dial down slowly? In a perfect storm situation where the build up at 60 amps and it just so happen that you turn on your AC or other appliances exceeding your max panel of 100 amps, won't that trip the entire main panel? That is what I understand. Even if you put in your wall charger and dial it down to 40 amps the initial build up is 60 amps.
TexasEV
7,640
8,464
Austin, TX
80% of 60amps = 48 amps.....48 amps is the max he'll be able to run continuously without the breaker tripping. He certainly can use 60 amps breaker.
You’re missing the point. The outlet is for a 50A circuit. If there’s a problem, a 60A breaker won’t trip to prevent a fire. Electrical code exists for a reason.
Reactions: Olds442
TexasEV
7,640
8,464
Austin, TX
No. The max a Gen 1 UMC can draw is 40A and the max a Gen 2 UMC can draw is 32A with the 14-50 adapter. The car and UMC don’t know what size the breaker is and it doesn’t start up high and dial down the amps. This has nothing to do with the Wall Connector. It’s an outlet. The breaker size has to match the circuit and outlet. Oversizing the breaker is dangerous.
Quickstart88
239
94
Orange County
Thanks!
ponzu
289
96
Southern California
Good price, questionable specs.
Is a 75 foot wire mounted to the house in a conduit, or just that, wire? I had a guy offer me the following as a solution. Said he did this for homeowners who need extra juice every once in a while, such as for parties. He installs a new 50a breaker and runs a long wire from the electric panel, terminating in a weather-proof plug. Essentially, a permanent extension cord. When not needed, coil it up on the ground under the electric panel, or wrap it around a rack if desired. When needed, which for me would be once or twice a week, unroll and run it to where the car (or the party) is. I did not go for it, but he said it would be cheaper than any other option. Other options given how far my panel are about $900.
I feel this discussion will be all about safety and not really about the cost, which, obviously, you did good on.
Quickstart88
239
94
Orange County
@ TexasEV - Can I get your blessing on this. I am using Gen 2 UMC, #6 wire, 40 amps breaker. My panel is max out at 100 amps.
The spec calls for a 50 amps breaker. I thought it would hog up 50 amps and dial down slowly. Therefore I am staying with 40 amps breaker. Is this okay or should I go with the 50 amps breaker?
TexasEV
7,640
8,464
Austin, TX
First off I’m not an electrician and I don’t think 240V circuits are a do-it-yourself project. But the Gen 2 UMC only pulls 32A so in that regard you should be OK with the 40A breaker. The problem comes when you sell the house and the next owner sees the 50A outlet and plugs a Gen 1 UMC or RV into it.
