There is a thread here where someone purchased all the different manufacturer versions they could find and compared them. Leviton was by FAR the worst.
Is this the one?
That is a UMC 1 adapter not third party.
If it were the Gen 1 itself that failed I don't think it would have shown up as a loose wire.
How did you come to own a Gen 1 UMC? IMO that's probably the culprit. I've had two of those die on me... I suspect that was one reason the Gen 2 is 32A. What current were you pulling when it died?
I believe 40 amps.
I'm glad that nothing more serious happened!
Note that plugging the UMC directly into the outlet rather than using the 3rd party adapter (what kind was it?) might have prevented this, since the UMC has a thermal cutoff sensor.
Instead of the HPWC we went with a NEMA 14-50 and instead of using the mobile with adapters we bought the corded 14-50 mobile connector. So are you saying that's a safer way to have gone?
Buy the Hubbell 14-50r when you replace it. It is much better built.
https://www.amazon.com/Hubbell-253-1454-HBL9450A-Receptacle/dp/B000J15QW2
The difference in price is dramatic. Amazon has the Leviton listed for $8.15. The Hubbell is $102.50. I believe I paid in the $60 range several years ago.
Not sure how you're jumping to that conclusion. The wall charger obviously has one less contact surface for the current to travel through, but as long as your outlet is in good working condition, the corded mobile connector will be fine. It also has the same temperature sensor in the plug as the UMC gen2 adapters.Instead of the HPWC we went with a NEMA 14-50 and instead of using the mobile with adapters we bought the corded 14-50 mobile connector. So are you saying that's a safer way to have gone?
Did you get the work inspected by the city for a permit after the install?View attachment 416959 View attachment 416958 View attachment 416954
My main house breaker tripped tonight. Upon investigating, I saw black smoke curling up my garage wall and smelled burning plastic, from where my 14-50 plug is located. Turns out my electrician had installed the plug with a loose black conductor, causing the outlet and plug to meltdown. At this point I am much more relieved than upset because I was able to stop what could have been a disaster. I will be double-checking every connection myself going forward in the install of a HPWC to replace the 14-50! If you smell burning plastic, investigate!
Yes.Do you really think that's the weakest link in the electrical chain?
