I install all outlets with ground on the top, so that if the weight of the plug starts tugging it out, it will expose the grounding conductor instead of the current-carrying conductors.
That was a kind of unofficial Canadian protocol back in the '60s. Someone once told me it was a sign that the wiring was done by a Union electrician. You rarely see it any more (typically ground pin on the bottom).
I was told by my electricians that this is best modern practice even for 5-15s, and is done also in case something metal falls on top of a loose plugThat's BS. I install all outlets with ground on the top, so that if the weight of the plug starts tugging it out, it will expose the grounding conductor instead of the current-carrying conductors.
...however, I was also told that it is traditional to install 5-15s with ground pin down, and that there are so many plugs which require it that they usually do it that way for houses even though it's not considered best practices. But they install everything else with ground pins up.There is no "official" direction to install receptacles - my home's 5-15 eceptacles are installed ground pin down, while my shop's are installed ground pin up (although I believe the UMC's expect ground pin down for the 5-15).
Of course, I have several appliances with 5-15 plugs which want the ground pins up, so their cords are kinked... Well, whatever....
My 14-50 (which came with the house) was installed upside down. I simply shut off the cirucut, removed the front plate, unscrewed the plug mount and flipped it over. Reinstalled the mount and plate. Super easy, depending on your outlet housing (mind is a junction box in the drywall). I also got one of these racks for the cable:
Amazon.com: Racor SHR-1B SNAP2IT Hose Rack: Home Improvement
It works really well.
Thanks for the heads up and the link, that looks perfect! I'm going to order one right away.
This forum has been a terrific resource for great accessories like this that I've been really glad I ordered. I've also taken advantage of the links to: cargo nets, LED license plate bulbs, car mats, protective film for the 17" display. Now all I need is my car! My delivery windows starts in 4 days. :love:
I've seen some garage photos posted here with people using a tornado brand hook (easy to find at home depot)
any concerns about kinkage? I bought one, but haven't installed it in the garage yet.
I am having mined flipped. Don't like the way it bends the cable.
I would like to test the installation before plugging my MS. Does anybody know how to test NEMA 14-50 after install? Any help is really appreciated
