NEMA 14-50 quotes
Discussion in 'Model S' started by Keith909man, Sep 24, 2017.
Tags:
  1. Keith909man
    Keith909man Member
    Tacoma wa
    thinking about hiring someone to install a NEMA 14-50 in my garage where my panel box is located and wanting to get a ball park idea what I should be expecting to pay. I've heard don't use the tesla recommendations... I'm in the Tacoma Washington area
  2. Lasttoy
    Lasttoy Member
    St Augustine, Fl
    Do it yourself, watch you tube videos, I did mine in one hour, they tell u exactly how, and what.
    Cost under $100.
    List, 14.50 box at home depot $50. Roll of 8.3 wire 25, double 50 amp breaker 25. Your HD might more or less .
    Quick , decide on close place to breaker box, wire outlet box, mount it, run wire to CB box . Turn off main house power, if you can pull meter do it. Install breaker, run red wire to one side, black to other side, green and white go to same bus.
    This is not rocket science, very easy if breaker box is in garage.
    Good luck.
  3. Lasttoy
    Lasttoy Member
    St Augustine, Fl
    If I can borrow your Tesla, I will do it.
    • Funny x 2
  4. Keith909man
    Keith909man Member
    Tacoma wa
    YouTube link that you used?
  5. YauKwan
    YauKwan Member
    New Jersey
    #5 YauKwan, Sep 24, 2017
    Hire someone unless you really know what you are doing. Should be $500 or less for a short run like that.
    @Lasttoy hope you didn't use 8/3 cable. For continuous draw @ 40 amps and to be code compliant you need 6/4 even if tesla doesn't use one of the cables. It also will need permits and inspections
    You Also need to see if your panel will both physically(space for two pole breaker) and capacity wise(additional 40 amps) support the additional load.
    If not a service upgrade will run $2000+
    You bought at least a 50k car. Spend the 1% and hire someone to not burn down your property.
  6. arcus
    arcus Active Member
    Denton, TX
    For what it's worth, I was quoted close to $1,000 from the Tesla recommended electrical companies. I asked the facility maintenance folks at the company I work at and they said it should be no more than 200-300 bucks when done by a certified electrician.
  7. Vin_Di
    Vin_Di Member
    Orlando
    I had a certified electrician do a similar installation in my garage and it was about $300 including hardware. Install was in garage about 6 feet from panel, however he had to fish all the wiring inside wall to get it to my preferred location.
  8. mongo
    mongo Well-Known Member
    Michigan
    Clarification: should be 6/3 (the 3 is the number of insulated conductors, NM-B has an uninsulated ground wire also, 4 conductors total. Also requires protection from physical damage)
  9. Webeevdrivers
    Webeevdrivers Member
    Canada
    300 bucks for us here in Canada. Parts and labour. Canadian currency. Maybe 8 feet from the panel.
  10. Lasttoy
    Lasttoy Member
    St Augustine, Fl
    My bad, didn't ch my writing. It was6.3 red, black, green, white, 50 amp breaker. I only had to go 6 feet. In florida we dont do permits and inspections when done by owner. But it is in code. Its really hard to screw up if not far to go, you put red and black in correct spot. But it can be scary if you are not a geek.
  11. demundus
    demundus Member
    Oceanside, CA
    i paid about 2gs to do mine but it was a 75 foot run with some trenching and I added and extra fuse disconnect in the garage for my own piece of mind. I had an entire thread on it somewhere. If mine was in there garage already (like most homes) I woulda done it myself, its really not that hard as Lasttoy says
  12. GooseVR1
    GooseVR1 New Member
    Denver, CO
    I used a Tesla Recommended electrician, who I thought was reasonably priced, at about $800, less the permit fee. I needed a 80 foot run (in conduit of course) from my panel. NEMA 14-50 outlet.
  13. Silverstreak
    Silverstreak Member
    Indiana
    My service is in garage and the install was about 360 usd
  14. P100DHG.
    P100DHG. Supporting Member
    Burbank, CA
    If your panel is surface mounted this job is a piece of cake. I did my NEMA 14-50 on my garage panel for like $30 in material, my High Power Wall connector in the driveway was $40 for the permit and $200 in material this was run from my panel under my house and through the wall for a completely hidden install. My run was a total of 70 feet. Depending on the run the electrician is going to use between $30 and $250 in material. The rest is labor. My electrician charges me $50 per hour for jobs I need his help with. He didn’t help me on either of those two so I got away with material cost. Hope this helps.
  15. Mark Z
    Mark Z Active Member
    North Orange County
    Depends on location of the circuit breakers and the NEMA 14-50. Mine is on the garage wall directly behind the outdoor circuit breaker panel, so there was minimal distance. The 50 Amp RV connection box with included NEMA 14-50 is about $28 at Lowe's. Total cost with wire, circuit breaker, and electrician labor was $180. Expect to pay more if permits are required by the electrician.
  16. JPUConn
    JPUConn Active Member
    CT
    Get 3+ quotes and for the non tesla shops just ask for a Nema 14-50 with a 50 amp breaker and 6awg wire. Try to avoid letting them know it’s for a tesla if you can to avoid the markup.
    I had 2 tesla recommended shops quote $1,500 - $2k for a 30 ft run with plenty of room in the 200 amp panel. Then had 2 licensed electricians both quote $4-500. I ended up doing it myself for under $200 in materials and pulled a permit with my municipality and had it inspected. If you are not 100% certain of what you are doing, don’t risk it.
    I also installed a 14-50 at my in-laws right next to the panel in their garage for destination charging when we visit. That install was incredibly simple and much less expensive (just needed the breaker, box and outlet as I had the 1-2’ of wire leftover from my install)
    For your install I’d say $200 would be reasonable for a licensed electrician.
  17. ThisIsTrue
    ThisIsTrue Re-member
    'Western Slope' Colorado
    Yeah, having "Tesla" in the quote probably doubles the price.
    We called in our regular electrician (used them before). I had them install my HPWC and a 14-50 (to have more flexibility/room for expansion/guest accommodation), with separate breakers, of course, right by the box. Total cost: $500. (Colorado, no permit needed.) @Keith909man's mileage may vary.
  18. Bebop
    Bebop Active Member
    Chicago
    If you install the plug right under neath your panel, it should be around like $100 or so.
  19. GaryW
    GaryW Supporting Member
    Raleigh, NC and sometimes Titusville, FL
    My electrician ran me $360 parts and labor. I wanted the plug 15’ from the panel. It took 25’ of 6 AWG,plus the conduit, plug, and 50 amp breaker. It looks nice.
  20. Qbenjamin
    Qbenjamin Frugal But Classy!
    Tampa
    $279 for a 14-50 to be mounted just beneath my electrical box in the garage. I did have another electrician that came later and said that price was a rip off...
