Do you have 200AMP service? The ESA gets all bent up with 100AMP panels and electric chargers.
I would also consider installing a 30AMP plug, there's no need for 50 AMP, the mobile charger max charge is 32AMP (40AMP breaker), but there's nothing wrong with using a 24AMP feed - (Dryer plug 30AMP breaker), that' plenty of juice
Going this route may get ESA off your back
See attached - 24AMP charging speed
I have a 100amp service and had an electrician install a Wall Connector and it connected to a 50amp breaker with the WC set to 80% (40amp).
The process was straightforward - I downloaded 2 years of my data (1hr resolution) from the Hydro Ottawa web site, sorted it from highest to lowest consumption. Both ESA and the electrician looked at the data and both approved the 50amp breaker. I was a bit worried that ESA was going to cause a fuss, but he looked at the data and was perfectly fine with 50amps.
I have AC, an electric dryer, a pool pump + the normal stuff. My water heater, pool heater and stove/range are all gas. My peak usage in the past two years was about 10Kw.
Edit: I had Sega electric do my install and they were great to work with. I installed the Teck cable they specified which involved getting it through my finished basement ceiling. They came and spent two hours installing the breaker and the wall connector. All in they charged $800. That included the taxes, the inspection and the breaker (which is hard to find and had to be ordered in from the US and cost $200 by itself). The cable I purchased, and I purposely used a thicker gauge cable with an extra conductor to future proof the install.
