When we buy something from the store, for electrical products, there us UL listed sign. Hopefully there is some quality control telling us if it is rated for 50 amps, it is not only for 30 amps. If we don't trust that, everything you buy will be subjected to doubt.code species all work to be done in a "neat and workmanlike manner" as well as installing equipment per manufacturer specifications. From what you describe, the work wasn't done to code.
I have been using extension since 2014 on the NEMA 10-50 outlet with no issue. I will not charge 2 EV by using a splitter concurrently. I intend to by a 10-30 splitter and charge two Tesla's alternately.I had 25ft long extension cord for 2 months with zero issues on old 10-30 outlet charging my X every night with splitvolt 10-30 splitterzero issue. Cable was thick af, so I guess good quality cable helps
I am not sure what you meant by extra points of failure. Extension cable is like a wired conduit to channel electric current to the car. How could it harm the car especially after I used it since 2014 with no adverse events.I never recommend using an extension cord for daily charging. There are just too many extra points of failure for it to make sense. You just paid a lot of money for a luxury car, pay a little more for a proper charging circuit. It will be safer and more convenient.
Adding an extension cord means at the very least two more significant failure points. Both the line voltage spades of the extension cord are under high stress, and you are adding N feet of unprotected cord that might be physically damaged anywhere along its length. You also should be concerned about the connections from those two spades and the wiring of the cord, and from the wiring of the cord back to the things that receive the spades of the UMC's adapter.I am not sure what you meant by extra points of failure. Extension cable is like a wired conduit to channel electric current to the car. How could it harm the car especially after I used it since 2014 with no adverse events.
A quick google search for required permits indicates one is required for electrical vehicle chargingI am not sure what you meant by extra points of failure. Extension cable is like a wired conduit to channel electric current to the car. How could it harm the car especially after I used it since 2014 with no adverse events.
The connection types are not the same. Using spring tension to have the inside pieces of metal in an outlet "squeeze" against the blades of a plug is a less reliable and less surface area and more resistive connection than wire lugs with screw pieces that tighten down to pinch HARD onto a wire. Those are more solid connections. Electric code won't even allow plug connections for anything above 60A because it's just too dangerous and unreliable for high current applications.I am not sure what you meant by extra points of failure. Extension cable is like a wired conduit to channel electric current to the car.
It won't. It's not about the car. It's about the connection points of these plugs developing problems and getting loose or more resistive and forming hot spots, which can be dangerous if it catches something nearby on fire. So it's preferable to not have a lot of those kinds of plug connections in the chain of high current applications like this.How could it harm the car
As others have said, it's those extra plug connections, plus trip hazards, exposure to dirt and moisture, etc... I don't want to be overly dramatic. Your car is not going to blow up or anything. I know that many people have used them to no ill effect, and I've used them myself for temporary situations like at a relative's house. I just think that for a permanent situation, it's smarter, and certainly more convenient, to do it correctly.I am not sure what you meant by extra points of failure. Extension cable is like a wired conduit to channel electric current to the car. How could it harm the car especially after I used it since 2014 with no adverse events.
I literally charge it everyday with extension cord and splitter... under the rain, wind, day and night when needed... had zero issues. Choosing the correct extension cord is important.I never recommend using an extension cord for daily charging. There are just too many extra points of failure for it to make sense. You just paid a lot of money for a luxury car, pay a little more for a proper charging circuit. It will be safer and more convenient.
What type of splitter are you using?I literally charge it everyday with extension cord and splitter... under the rain, wind, day and night when needed... had zero issues. Choosing the correct extension cord is important.
Lack of failure ≠ safetyI literally charge it everyday with extension cord and splitter... under the rain, wind, day and night when needed... had zero issues. Choosing the correct extension cord is important.
