NEMA 14-50 to 6-50 adapter
allyourbase3
New Member
Feb 12, 2020
Tulsa, OK
I installed a 14-50 outlet in my garage but am getting worried since the 14-50 adapter has been sold out for a while. I see there are 6-50 to 14-50 adapters made by third parties. Since the 6-50 adapter is available from Tesla, could I use a 6-50 to 14-50 adapter and not see a large drop in charge speed?
Sophias_dad
911
765
Massachusetts
You'd see no charge speed loss, but it would be a tiny bit more dangerous.
The UMC adapters have temperature monitors in the plug-end so it can detect if the outlet is overheating. If you put in a 6-50 to 14-50 adapter, the 14-50 end might overheat and the UMC would never know it.
In any case, the UMC is only able to move 32 amps, so it isn't likely to overheat either plug...
Or you could just buy one on ebay, but I'm 'shocked' at how expensive they are. Maybe I should put mine out there!
PJFW8
Red Menace may hurt me
May 29, 2015
383
274
Hendersonville, NC
There will be no drop, the only difference is that the 6-50 has no neutral. Tesla (and no EV of which I am aware) does not use the neutral. The neutral allows a 120 volt option. Stoves and some driers use 240 for heating elements and 120 for lights and controls, in case you are curious! Go for it!
Rocky_H
5,848
6,684
Boise, ID
Yes, generally fine and transparent to the car. It would just be a simple pass-through of the pins/wires. For general recommendation purposes, as long as you are keeping the same amp level, so the Tesla plug is signaling the correct limit, these are fine to use pigtail adapters like that. It just gets sketchy when people try to adapt from a lower amp plug to a Tesla 14-50 or something where the car could try to overdraw the circuit if you don't manually intervene.
Rocky_H
5,848
6,684
Boise, ID
Why don't you just replace your 14-50 outlet with a 6-50 outlet?
Well yeah, since you can get the 6-50 plug from Tesla, just change the outlet type, and then you don't have to do any hokey stuff with third party pigtails. For car charging, they are functionally identical. I had kind of overlooked that idea because I was thinking this was like a rental or something, and you couldn't change the outlet for some reason.
Sophias_dad
911
765
Massachusetts
Its a long shot, but you might want to check your local service center. They used to have stocks of wall connectors when the website didn't have them.
But yeah, a 6-50 outlet is like $10.
tilt
77
68
KC Metro Area
Just got a shipping notification. Says it is a 14-50 adapter in the order and shipping confirmation. Fingers crossed that that is what will actually show up.
Rocky_H
5,848
6,684
Boise, ID
I was actually checking because I sold(but not quite shipped yet) my 14-50 to OP at no profit and wanted to see if he could get it direct(without paying me for shipping). I would have refunded him 100%.
It was joking, obviously and I was referring to @tilt anyway, who was able to swoop in and get one, and then they were sold out for you.
