NEMA 15-50R to 14-50R
I'm visiting my son in Georgia in a few weeks, and will be taking my new Tesla. His ice cream shop has two ice cream makers that use a 3-phase 15-50R. I'm looking for an adapter to (or make my own) allow the S to charge from those outlets. Am I right in that all I need to do is use 2 out of the 3 legs to get 208V? Is this safe and has anyone been successful in charging the model S on this type of plug?
Thanks!
This is what his plugs look like:
I've never seen an outlet like that before, but your approach sounds correct. US Model Ss are equipped to handle single phase only (European cars have three phase chargers...)
I believe a lot of EVSEs at commercial sites are wired as you describe, at 208V.
Walter
They are a little pricey, but your idea should work.
HUBBELL HBL8452C AC Plug NEMA 15-50 Male Angled - Electric Plugs - Amazon.com $64.00 + $9.99 shipping
Just remember that this will be the same as a 6-50 to 14-50 adapter. There is no neutral to connect to the neutral in the 14-50. The UMC will work, but label the adapter very well so that an RV user will not use it and blow many of their 120V devices.
Sounds workable, but someone who understands commercial 3 phase power, like FlasherZ, should weigh in. Looks like you would connect the grounds together and then X and Z from the 15-50 to the two hots of the 14-50, and leave the 14-50 neutral unconnected. Use 6 gauge wire for the interconnect.
Yes, I was thinking of using X/Y and leaving out Z, but I guess it doesn't matter? No need to connect W of the 14-50 to anything?
View attachment 84852View attachment 84853
Yes, G to G, X to X, and Y to Y should work fine for the Tesla UMC, leaving Z (Phase 3) unconnected on the 15-50 and W (neutral) unconnected on the 14-50. W (neutral) unconnected on the 14-50 can produce unexpected voltage for an RV or other use that is expecting 120 Volts, W to X, and W to Y. That is why the adapter needs to be clearly and boldly labeled "Only for Tesla Charging, Not for RV Use" or something like that.
See NEMA connector - Blade identification - Wikipedia for reference.
That's just what I needed, Thanks! I'll test voltages on the 14-50 before I actually connect the UMC to make sure everything looks good!
Isn't that just an open circuit? Similar to a circuit with a switch on the neutral.
You typically don't want to switch neutral due to human safety reasons, but it doesn't harm 110V equipment if you do. (It doesn't work of course... but it's not harmful).
It's not an open circuit. It's very harmful to 120V equipment. Remember that neutral is a grounded center-tap of the transformer that carries the imbalance between leg 1 & leg 2. Allow it to float, and you'll get imbalanced voltages based on the current drawn across the legs.
Imagine appliance 1 between L1 and neutral, and appliance 2 between neutral and L2. Current will flow; the completed circuit is L1-app1-N-app2-L2, with neutral floating.
- - - Updated - - -
For most 3-phase power, this will work. You may end up with 208V or 240V, depending on whether it's a wye or delta configuration. The 18-series receptacle is for wye when neutral is required, the 15-series receptacle can be used for delta or wye when only L-L is needed. The wiring Cosmacelf spoke of will work either way. As mentioned, label that adapter 6 ways from Sunday with "NO NEUTRAL - TESLA CHARGING ONLY".
Right, of course - you still have the neutral connected between the 2 legs on the other side of the circuit. My bad.
- - - Updated - - -
Thanks FlasherZ! I'll be sure to label it properly :)
So I am staying at an Airbnb next month, and the house has a "NEMA 15-50 EV charging outlet" included in the listing. I confirmed with the host that it is indeed a 15-50 and not a 14-50 outlet. I tried following the discussion above, but I'm still sorta lost. Is there no simple "plug and play" adapter I could buy that I could use with the UMC to charge from a 15-50 outlet? The Tesla store doesn't list a 15-50 adapter as being available.
Unless the Airbnb is in a commercial building, the most likely explanation is that the host is wrong. Have him send you a picture.
Reactions: Rocky_H
