I am becoming a big fan of 6-15/6-20 charging for power limited locations!
My houses have 600 Amp service, and putting in a 100 Amp circuit for 80 Amp charging with an HPWC in each place was pretty simple. On the other hand, I now have three places where I may need to regularly grab a charge. One has a 100 Amp panel, and the other two have 50 Amp panels. Now I need to be a little more thrifty in my thinking at these new locations. In all three, a 240V/20A breaker will fit to allow installation of a 6-20R for charging.
I did some testing with my HPWC tonight set to 12 and 16 Amps at a nominal 240 Volts. Here are my results:
Voltage | Current | Displayed MPH | Calculate MPH |
243 | 12 | 8 | 8.86 |
243 | 16 | 12 | 11.74 |
While the resolution of the displayed MPH charging has a lot of quantization, my calculations on charge rate are very close to 16/12 or the current ratio. These calculations were done from actual charging to get better resolution, not from the basic V*A input, so represent actual charging performance with better resolution.
I can use the 6-15 adapter for 12 Amp charging, or with another adapter in between, use the Tesla 5-20 adapter for 16 Amp charging. I like having the current setting in the adapter for regular charge locations to avoid mistakes. The 5-20 will work, but I sure wish Tesla made a 6-20 to avoid possible mistakes that would fry a 120 Volt device.
My prioritized list for new Tesla, UMC adapters is:
- 6-20 — Needed for power starved locations
- 14-30 — Needed for less power starved locations, new-style dryer outlet
- 6-30 — Needed for less power starved locations, fewer wire install
- TT-30 — Needed for old Camp Grounds
- 6-50 — Fewer wire install for 40 Amp charging
