NEMA 6-20 from two NEMA 5-15 outlet on different phase for faster charging?
Is that possible to connect a NEMA 6-20 socket to two NEMA 5-15 outlets on different phase (180 degrees) with some 14 AWG cables (Shown in the photo)? Is that 20 means 20 amp total (10 amp/phase) or 20 amp/phase?
pxl_20201203_024826485-jpg.613978
This is wrong on so many levels. First, combining 2 out-of-phase NEMA 5-15’s will provide 15 amps at 240 volts, You double the voltage but you don’t increase the amperage. Second, the example you show is dangerous because as soon as you insert one plug, the other will become hot and therefore an electrocution hazard. Don’t do this.
The Quick220 is a good solution because it has a switch to prevent the electrocution hazard I just mentioned but it, too, must be used carefully. Do a search on this site for Quick220 and you’ll find discussions on the dangers of misusing the Quick220.
Seriously - please don't skimp on costs and/or the lack of level 2 charging capabilities with these kinds of "hacks". They're not within miles of electric code and can easily shock/kill you or someone else. Even worse, they could easily start a fire if something goes wrong in even the smallest of ways.
As already stated - hire an electrician! The amount of money spent for this particular purpose is pennies compared the costs of repairing damages when one of these ideas goes wrong.
As stated above - 2 15a 120v outlets would combine to a 15a 240v outlet.
But, for everyones safety, if you must do it, use a quick220 device or get with the landlord about authorizing you to hire an electrician and modifying the property. if it is near the breaker box it might now cost much money.
If anyone (landlord, their designee, family, friend) pulled out one of the plugs in the self made rig and was electrocuted it would be much bigger problems financially and mentally.
Reactions: MorrisonHiker
