  • The final cut of TMC Podcast #34 is available now with topics timestamped. We covered Tesla's rollercoaster prices, Toyota pushing junk science, Mike's new Model 3, Optimizing track mode for snow driving, FSD V11 apparently coming by the end of this week, and more. You can watch and check out the chat replay on YouTube.
NEMA 6-50 outlets: Leviton versus Bryant
Big Earl
bnkwupt
8,011
16,151
La Conner, WA
I'm guessing the Bryant/Hubbell is better than the Leviton, but see above discussion. It's not completely obvious.
I thought Tesla previously published a list of recommended 14-50 receptacles. I could be wrong.
EDIT: Tesla instructions on installing a 240 volt outlet do list two example 14-50 part numbers - Examples: Hubbell part # HBL9450A, Cooper part #5754N
Thanks for linking that document. It's nice to see that Tesla does specifically recommend installing a high quality, industrial grade receptacle, specifically the Hubbell and Cooper.
Reactions: thefrog1394
For the 6-50 receptacles, the Bryant appears to be better than the Leviton in terms of contact with the plug blades, which should reduce the chance of overheating at the plug that you experienced.
It does not appear to be better at the wire connections, since the Bryant and Leviton use similar screw-down clamps (indeed, the Leviton has bigger screws) for the 6-50 receptacles (unlike for the 14-50 receptacles where at least one Bryant model has a more mistake-resistant wire attachment method).
tps5352
...btw: Tesla would be foolish to publish a "list" as every DIY'er would use it and would blame Tesla for a bad install.
Right. I hear that back in the day (when Tesla 40-amp Gen 1 mobile home connector equipment [e.g., Tesla UMC and CMC] was the norm) Tesla at first promoted the installation of NEMA 14-50 receptacles (and the $520 Tesla Corded Mobile Connector) on their website. But too many reports of home plug/receptacle failures ensued. (Probably often the result of questionable installation practices by DIY'ers, rather any problem with the Tesla charging equipment per se.) Anyway, more emphasis began to be placed on having licensed professionals install Tesla wall connectors (along with adequate wiring and breakers). (Plus Tesla lowered the maximum charge rate to 32-amps for its Mobile Connector.)
...EDIT: Tesla instructions on installing a 240 volt outlet do list two example 14-50 part numbers - Examples: Hubbell part # HBL9450A, Cooper part #5754N
On yeah, there it is. Note how 'dated' the content is. The Gen 1 UMC is still portrayed. (Things change so rapidly in Tesla-world.)
Wow. I predict there will be many house fires that start at 14-50 receptacles as EV adoption increases. I prefer hardwired and think code requirements should go in that direction as well.
Yea. I also expect to see better "EV-grade" 50 amp receptacles. I can plug a 1500 watt space heater into a 5-15 plug and not worry about whether the receptacle was a "heavy duty" version. Your average 30 or 50 amp outlet is typically used for intermittent loads often well below 50 amps. EV charging stresses these outlets much more and so higher quality receptacles are needed. Although frankly it seems crazy to me that these companies can market their outlet as 50 amp capable when they melt after sustained 40 amp loads.
Leviton is quite possibly the worst brand to use for any receptacle. It feels like a lightweight child's toy vs other brands. The Lowe's brand Utilitech is so much better for a budget receptacle.
TBH I didn't notice much difference between the Utilitech 50 amp and the Leviton, although I didn't spend much time comparing them. I used the Ulititech b/c that's what Lowe's had on hand and I needed to charge my car b/c it was sitting at like 4% state of charge and I was leaving the next morning. Hopefully that one lasts longer, although I will be (for unrelated reasons) using this plug for only a fraction of my charge sessions going forward, so unfortunately it won't tell us much.
Reactions: father_of_6
Do the contacts in the plug holes of the Utilitech receptacle contact the full plug blades, or only part of the plug blades?
See my post below for in depth pics. Certainly seems much better IMO.
I’m currently working on a (temporary and infrequent) charging solution away from my house with a 14-30 outlet. I picked up the $10 Utilitech 14-30 in the pics below from Lowes; they have the same one available in a 14-50 as well. Based on the pictures I’ve seen in this thread, it certainly looks like a much more quality outlet than the Leviton for the same price. I’m not saying I would recommend this to someone as a permanent charging solution (you really should just buy the wall connector), but for the same price as the Leviton it certainly seems to be a much better choice for those with cheap outlets who didn’t spend $100 on the Hubbell outlet. For my purposes this should work perfectly fine as I’m swapping this outlet with an already wired dedicated circuit L14-30.
View attachment 739219 View attachment 739220 View attachment 739221 View attachment 739222 View attachment 739224
Big Dog
1,942
2,197
Irvine, CA
The word "intermittent" is key. Even a space heater cycles on and off. An EV draws continuous full power for hours, building up heat, eventually causing a low-end circuit to fail.
One other thing noticeable about different outlets is that the contacts in the Leviton plug holes look like they are steel, versus brass in most other outlets. Although brass is less conductive than pure copper, steel is likely to be less conductive than brass, according to https://www.bluesea.com/resources/108/Electrical_Conductivity_of_Materials and TIBTECH innovations: Metal properties comparison: electric conductivity, thermal conductivity, density, melting temperature .
So a less conductive material contacting only about half of the plug blades seems like a formula for more resistance and heat compared to a more conductive material contacting the full plug blades.
Seems odd that a receptacle that overheats at the plug interface under 32-40A continuous load could be rated as a 50A receptacle that should be able to handle up to 40A continuous load.
The contacts in the utilitech (above) look like they contact the full plug blades.
There's definitely something weird going on with the contacts in the Leviton plug (below). It's hard to capture in a picture, but the inside contact is much smaller and, on the melted side, very misaligned. The contact is loose on that side, so I suspect the extremity of the misalignment is due to the melting of the plastic holding it in place.
TLDR, the Leviton NEMA 6-50 outlet seems to have a pretty severe design defect. I would highly recommend against using one of these, regardless of application. After looking at this closely, I'm frankly surprised there hasn't been a recall for this product.
Reactions: tps5352
The impression I've gotten over the years is that it is not so much due to inherent materials per se or even the primary design of the inexpensive receptacles*, but that rather it is often related to the cheap (e.g., flat-blade rather than hex screws) connections. The connectors can and apparently sometimes do come loose more easily with repeated heating/cooling cycles. After so many months/years, you can get arcing and, what you see in your photo. Of course, if installation wasn't adequate (It can be harder to tighten cheap connectors) this can happen even sooner.
You show the front of the damaged receptacle and the plug. What did the back of the receptacle, especially the connectors, look like, if you don't mind me asking?
However, since the excess heat appears to have been concentrated at the plug and receptacle, it is more likely that the half-contacts in the Leviton receptacle had something to do with it. This may not be due to wearing out, but because the contacts were significantly smaller than the plug blades to begin with.
Back looks fine (both photos above are of the melted Leviton plug). I don't think the screw terminals played any part in this failure.
Reactions: tps5352
So far, no excess heat issues with the new outlet, either from the EVSE lowering the charging rate due to heat, or the feel test (feeling the plug and outlet for heat) while charging.
Since the new outlet has similar screw-down wire contacts as the old, but has full brass plug blade contacts instead of the half steel plug blade contacts of the old, that points to the plug blade contacts as the main problem with the old.
Hey! Looking around for that Cooper outlet (I need one that handle Al) and I see a bunch of Eaton outlets, did Eaton buy Cooper and is the quality still worth it? I keep finding Eaton 5754N
RayK
Safety Score 90 (Was 96!)
Apr 5, 2016
3,167
3,309
San Jose, CA
I don't want to sound alarmist but if I had a circuit which I was going to strain its capabilities (i.e., continuous high current) that is wired with aluminum, I'd replace the entire length with copper.
This is a pretty perennial debate — the AL is done to code, and is the metal that runs the service line into our house, but I understand people’s misgivings. As far as I can tell, it’s the low quality outlet with bad clamps and no space behind the wires and clamps (in the surface mount style) that cannot dissipate the heat properly.
RayK
Apr 5, 2016
3,167
3,309
San Jose, CA
I understand that service drops are done with Al and when installed to code on branch circuits, are supposed to be safe. However, several years ago the buried line running from the street and between the driveways of me and my neighbor's disintegrated into dust. I don't know the exact reason which caused the failure but I was shocked to see what amounted to powered aluminum inside the shell of insulation.
Yep, that would definitely scare the hell outta me.
