Definitely not. That's 480V AC (3-phase).
Edit: Well, in the world of "anything you could do", you could build a transformer to take it back down to 240V...![]()
...except that NEMA 16 is 4-wire grounding, not 5-wire, so there is no neutral. It's 3 phases and ground. (Yes, I'm working under the assumption that we are not hijacking ground as a neutral!)3-phase 480V has 277V phase to neutral. It MAY be possible, but maybe not using UMC?
Info from Tesla - 277v feed to Wall Connector (HPWC) - Which Cars Support It
Looks like the cars CAN take 277V, although S/X are a bit more sensitive.
IIRC, neutrals are only used to get 120VAC out of 240VAC. My apprenticeship memories are fading from lack of use....except that NEMA 16 is 4-wire grounding, not 5-wire, so there is no neutral. It's 3 phases and ground. (Yes, I'm working under the assumption that we are not hijacking ground as a neutral!)
But for the sake of argument, if it did have neutral, you could use an HPWC, but not a UMC.
Yeah, your memory is forgetting about 3-phase systemsIIRC, neutrals are only used to get 120VAC out of 240VAC. My apprenticeship memories are fading from lack of use.
Well this sucks.
And if you install it properly it might not even burn your house down! lulzYou can get a new 14-50 outlet at Lowes for $8.74.
'cuz what he needs to do is just change the outlet out so he can plug his car straight into 480V...You can get a new 14-50 outlet at Lowes for $8.74.
'cuz what he needs to do is just change the outlet out so he can plug his car straight into 480V...![]()
Huh? Nowhere did it say he "got the used plastic plug from work". I'm pretty sure a normal interpretation of the initial post is that this outlet exists at their workplace, and they'd like to plug into it to charge.He got the used plastic plug from work. I doubt his house is wired for 480V. The 14-50 is appropriate for home installation and for use with the Tesla charging cord. No one is suggesting using a 14-50 outlet with 480V supply.
Thats correct. Its at my workplace.Huh? Nowhere did it say he "got the used plastic plug from work". I'm pretty sure a normal interpretation of the initial post is that this outlet exists at their workplace, and they'd like to plug into it to charge.
