SByer
'08 #383
No, this has been great. It's starting to feel like it wants to be shrunk down to a laminated credit-card sized cheat sheet.
I'm not sure why the 14-50 is being singled out. I can put a 20A breaker behind an L6-30, and have the same problem. I can use 18 gauge wire behind a 120V 20A outlet and have the same problem. The 50A capacity is the capacity of this connector. That is all it means. If it is wired incorrectly, then it is wired incorrectly.
Hey, does anyone know the vendor for those yellow NEMA 14-50 plugs with the safety handle molded into the plug housing?
Thanks.
[FONT=Arial, helvetica, sans-serif]PowerMax [/FONT][FONT=Arial, helvetica, sans-serif]50 Amp[/FONT][FONT=Arial, helvetica, sans-serif] RV Generator Adapter Cord NEMA Plug[/FONT]
[FONT=Arial, helvetica, sans-serif][FONT=Arial, helvetica, sans-serif]Note: for RV use only, 30A 120V maximum power input, cannot be used for any 220v applications.[/FONT]
Noticed this one from your eBay search:
PowerMax 50 Amp RV Generator Adapter Cord NEMA Plug - eBay (item 120425705810 end time Jun-24-09 08:39:55 PDT)
( Yet they describe it as a 50 amp cable! )
In RV lingo "50 amp" means 120V@30amp over a NEMA14-50!
Probably about time we included a picture of EVnut's cable set here:
That 10/4 stuff they had in there was for the wire - 10 gauge, 4 conductor.[FONT=Arial, helvetica, sans-serif]NEMA l14 - 30P to NEMA 14 - 50R cord[/FONT]
[FONT=Arial, helvetica, sans-serif]L14-30P
