I'll bet a miles worth of electricity that it was an error screen that said...
If so, my understanding is that it is a low voltage warning. Check the voltage readout on the VDC after it gets going, and with anything else running that may have been running when the error occurred. Far as I can tell, it's a somewhat innocuous error. At least Tesla didn't seem too concerned when I asked about it, in terms of damage to the car or anything. It'll still charge. I had the same issue with one circuit in my garage. It would pull from 110 ish V down to 99-101 under load, varying by whether I had it set to 12Amp or 15Amp. I had to search around for a different one, which reads 118V no load, and 110+ under 12 or 15 Amp load.
A separate MC120 thread would be great. I don't get that number of MPH charging from mine. I get more like 2.5 to 3.6 ideal range miles per hour of charging. I'm Keeping a log though to track it over time, since the ideal range number does vary - even had it go a couple miles down *while* charging between one hour mark and the next reading an hour or so later.
