For anyone changing cars there can be (rare) occasions where one can hit the wiper switch because your previous model or a recent rental had the lights or indicators there Yesterday I absentmindedly put the gear into Neutral when intending to indicate and then wondered where the regen had gone ..... As you'd expect, we can't select Park or Reverse while driving. But this made me wonder why switching from Drive to Neutral is allowed by the system. What is the use-case?
The car is still on Way better than my old fools fuel manual transmission ICE... I'd turn the engine off on long gentle hills... steering and braking is a bit harder without hydraulics. But still possible
When parking you may want to coast into a spot (when creep is on, but let’s not start that pro and con). We use the parking ‘humps’ in our garage and the space is so tight that sometimes you want to use neutral to ‘fall’ into them. Not exactly sure why having neutral available is even a question....
they won't, but coasting is illegal and shutting our car off too. both as you need to be in full control of the vehicle at all times. For example in case you need to suddenly brake (Where being in gear adds engine braking) or if you need to suddenly accelerate to dodge something.
If you're hydroplaning, one of the best things to do is put your car in neutral and don't touch the brakes. It prevents unintended engine braking or acceleration. Of course once you're out of the hydroplane you would put the vehicle back into drive.
But there are reasons in an ICE machine to have neutral (coasting to save fuel on downhill) or towing. Neither apply to the Tesla. Just seems an odd hangover.
I'd like to know what prize you get for 100 points. Or is it a thousand. Holiday for two paid in full?
I believe we have a big winner. Depending on particulars, coasting saves “fuel” in a Tesla too. There are tons of old threads about this, extending back years. The outline is, round-trip efficiency of regen is in the 60% range, whereas kinetic energy doesn’t suffer such losses.
Prob some silly law about having the ability to shift into neutral should your ICE engine throttle get stuck or something.
well it is also not illegal to jump out of a window in all states. doesn't mean it is a good idea though. You shouldn't give up control of the vehicle. If you are on a private road fine, but if you share the road with other pedestrian/cyclists/motor vehicles you gotta have at least some respect for those.
I do coast briefly on occasion. Usually when going down a slight downgrade, when the car won't speed up. Sometimes just to find out what my ancillary energy use is. I do not feel the loss of any control of the vehicle, on the contrary; I'm telling it what to do - in this case nothing. As long as you're over 5mph, you don't need the brake pedal to put it back into D.
