This is a Public Service Announcement or FYI for Tesla Roadster owners:
Never leave your Charge Port Door open unless you're sure that the charger is working (or at least ensure that you'll be back soon to check on status).
I live in an apartment with a ChargePoint system in the resident garage. The ChargePoint system has stopped working, and it's been difficult to get anyone from that company out to service the charger. I happened to park my car, open the charge port door, and prepared to start charging as soon as the system was repaired. However, several days went by, and I noticed that the battery dropped quickly. The VDS backlight stayed lit the whole time, showing "Preparing to Charge" with the battery charge meter displayed. I noticed each day that the battery was significantly lower than the previous.
Eventually, I got the hint and closed the charge port door. I also moved the car somewhere else where I could charge.
Basically, I'm warning folks that if you're going to park your car for a while with the charge port door open, then you'd better confirm that the charger is actually working. A non-working charger combined with an open charge port door seems to result in draining the battery faster than normal parking with the charge port door closed.
Note to self: I need to get around to installing the OVMS 3 that I have, so I'll be notified of status changes, and can at least remotely query the charge level and whether the car is draining or gaining.
