New 0-60 Times caused by new drive unit it seems...
Discussion in 'Model S' started by dakine1, Jul 2, 2017.
Tags:
  1. dakine1
    dakine1 Member
    phoenix, az
    This new Drive unit option is only showing up newer cars listed in the last few days. Compared it against mine and it does not have it. In fact they only have 1-2 of these available in inventory. This seems to be what will cause the speed increase. Now how can I break my DU and get the new one lol
    • Informative x 11
  2. lunitiks
    lunitiks ˭ ˭ ʽʽʽʽʽʽʽʽʽ ʭ ʼʼʼʼʼʼʼʼʼ ˭ ˭
    Prawn Island, VC
    Where's that screenshot from?
  3. gaswalla
    gaswalla P4201/85/airsusp/pano/19i
    San Diego
    Wow....great research. Thanks for the info
  4. Dazboj
    Dazboj Member
    UK
    Where do we find that information? Would love to see what my 'awaiting production' VIN says.
  5. dakine1
    dakine1 Member
    phoenix, az
    If your VIN is around 202-203 you should be good.
  6. lunitiks
    Prawn Island, VC
    Actually the code "DU01" shows up in the Design Studio image option codes. Maybe this is the new drive unit?
    @Dazboj try going to your "My Tesla"-page, right click on the large pic of your car and copy the adress to text. Look for "DU01"
  7. ShockOnT
    ShockOnT ⚡️⚡️⚡️⚡️⚡️
    Sydney
    Is the DU01 just the front motor on the dual motor car?
  8. dakine1
    dakine1 Member
    phoenix, az
    I believe that DU01 is the new DU for P models...
  9. dakine1
    dakine1 Member
    phoenix, az
    no. DV4W is AWD
  10. dakine1
    dakine1 Member
    phoenix, az
    And the 100s are getting the same NEW DU hence the close 0-60
  11. lunitiks
    Prawn Island, VC
    Actually "DU01" shows up in 75 kWh RWD and P100D ...
    "DU00" however shows up when choosing a 75D or 100D ...
    Confusing
  12. Orangejamal
    Orangejamal Member
    Lake Forest
    Am I looking at this incorrectly? Aren't both of the VIN's you posted both 203?
  13. lunitiks
    Prawn Island, VC
    Maybe this means that the new 75 RWDs are using a new, big P100D rear DU. (Rear DU 75 RWD = Rear DU P100D)
    While the 75D and 100D are using some other rear DU ("DU00")
  14. Dazboj
    Dazboj Member
    UK
    206 by the looks of it.
    No DU01.
    options=DRRH,FG00,MI01,PI00,COL3-PPSW,RFFG,TP00,WTAS
  15. lunitiks
    Prawn Island, VC
    Hm... You're not getting all the vehicle options. Should be like 50 or 60 different option codes in the URL
  16. andrewket
    andrewket Well-Known Member
    So DU00 is the smaller DU, and DU01 is the larger one.
  17. Dazboj
    Dazboj Member
    UK
    Got it from the 'View Spec' URL.
    Yes it has DU01 :)
    Anyone know the code for the High Amperage Charger?
  18. Karlton770
    Karlton770 Member
    Atlanta, GA
    Does this mean current AWD vehicles might have the new drive unit?
  19. lunitiks
    Prawn Island, VC
    #19 lunitiks, Jul 2, 2017
    CH00 Single Charger
    CH01 Dual Chargers
    CH05 ??? - probably it ;)
    EDIT: I found "CH04" on a the Design Studio new P100D... As well as on a use inventory X90D, where the page says "High Amperage Charger Upgrade"...
    Chaos complete
  20. Dazboj
    Dazboj Member
    UK
    I love you! My config shows CH04 :)
