2015 p85d
BMS_f150_SW_precharge_too__long
BMS_f073_SW_Unexpectd_HV_Sys_Bhvr
in the beginning: dreaded car may not start next time...SC replaces drive unit. 3 days after getting the car back... similar message. AND 12V is about dead. SC wants their pound of flesh and wants to charge diagnostic fee; lets change the battery heater for 1000...
I replace the battery and battery heater, similar error messages. cid dev chg screen shows battery voltage about .4v lower than voltmeter: replace IBS...
maybe a bad fuse or open switch in the front hvjb? i pull a houdini and pull the front hvjb... all 4 fuses have continuity...
obtain some hvil data:
bms hvil voltage 5.94v.
master hvil charger 4.76v
slave hvil charger 3.53v
the dcdc cycles intermittently. when it cycles on, the gremlins go away. otherwise the 12v dies and i get the faults:
if the bms is in fault state, the car can't charge, when the dcdc cycles, bms goes to support mode and i can charge. car has dual chargers...i an able to charge at 80a with dcdc active.
...help?
...help?
