New 19" tire on tirerack for MS
Discussion in 'Model S: Driving Dynamics' started by yobigd20, Mar 27, 2014.
  1. yobigd20
    yobigd20 Well-Known Member
    Skaneateles, NY
    I noticed a "new" tire on tirerack that fits the 19" OEM profile. Pirelli Cinturato P7 All Season Plus 245/45R19. It's ratings puts it in the top spot. Highest ratings/ranking for all 19s in this category. Definitely one to consider if needing new 19s to replace those OEM goodyears or michelins. And with a UTQG rating of "700" (I've never seen a tire rated this high), the tread *should* last a very long time.
  2. doc@tirerack
    South Bend, IN
    #2 [email protected], Mar 27, 2014
    Bear in mind that we are still in the "honeymoon" stages with the tire, so all those responding to our surveys are comparing the Pirelli to what ever they had on the vehicle before (most likely a fairly worn original equipment tire) and most likely have just few thousand miles of use on the tire. Once we get more than one million miles of reported use, the survey results should come down to reality. To get a better picture of what the tire can do, you can look at our test results (see the summary scores below);
  3. matbl
    matbl Member
    Sweden
    I don't get it why anyone would use an all-season tire. If you never or rarely encounters winter weather, get a proper summer tire. If you live where there is winter weather, you really need one set of summer tires and one set of proper winter tires. All-seasons are just crap.
  4. JST
    JST Active Member
    Not really. The all season Michelins are perfectly adequate for my needs; I'm not taking my family car anywhere near the limits of adhesion, so I don't need a max performance summer tire, and even this winter the snow here in DC has been mild enough that the Michelins have been perfectly fine.
  5. yobigd20
    Skaneateles, NY
    Summer tires SUCK in rain. I'm not driving around my family on summer tires when it rains 140 days out of the year here. All seasons are better for summer + rain, while admittedly they are not the best for HEAVY SNOW. But I'm not talking about snow here. I'm talking about rain. And for rain, summer tires "are just crap". So when there are tires that are good for summer + rain and good enough to get by in snow, hence the term "All-season", then yes that is exactly the tire I am going to buy.
  6. jerry33
    Texas
    That's true in Arizona, but if you live where it rains, you'll appreciate all-seasons. Summer tires aren't that great in areas where there is a lot of rain.
  7. matbl
    matbl Member
    Sweden
    I don't get the rain comment. ?
    In europe, all cars (except Teslas) are delivered with summer tires. In areas with lots of rain too. We get plenty of rain here in sweden and I've never had a problem with the summer tires in rain.
    The car magazines here publishes tire tests every spring and every fall. The all seasons are always the ones which perform worst. Including stopping distance on a wet road.
    Or do we just get better tires in europe?
  8. markb1
    markb1 Active Member
    San Diego, CA
    Summer tires are fine for rain, as long as you have sufficient tread. What they are not good for are freezing temperatures.
  9. xhawk101
    xhawk101 Active Member
    Saint Petersburg fl
    My stock Goodyear 19" have only 15 k on them and tread needing replaced already?? I know I've been stepping on the pedal but wow.... Is this typical?
    So suggestions for Florida 19 inch where we have lots of rain? Michelin primacy supposed to have better range ....want longer lasting too.
  10. MikeC
    MikeC Active Member
    Los Angeles
    I changed mine at 19k and they were pretty bad. I like the Primacy tires I have now but I'm interested to know if these new Cinturato tires will get better or worse range than the Primacy?
  11. gene
    gene Supporting Member
    Santa Barbara, CA
    I have 22,000 miles on my Goodyears with maybe 2,000 to go.
  12. Jason S
    Jason S Model S Sig Perf (P85)
    Rocklin, CA
    I adore the Primacy tires in the rain so far. And the dry.
    Very interested in competitor tires tho. Same interest as Mike, even though I hope it'll be a couple years before I need another set of 19s.
  13. cataber
    cataber Member
    Bucks County, PA, USA
    I just bought a set of the Cinturato P7s for my little brother for his Accord for his birthday. The thing that impressed me was the 700 on the tread life rating, so I'll definitely be keeping an eye on how he likes his Pirelli's for when I need to replace my Primacy's.
  14. dhanson865
    dhanson865 Active Member
    Knoxville, Tennessee
    tempature
    I live in Tennessee where it gets cold on a regular basis but hardly ever snows. Summer tires suck when the road is dry as can be and 35F.
    I have no need of two sets of tires here. In the last 15 years I've had to drive in snow where traction matterd less times than I can count on one hand.
    But I do have to drive on dry and wet pavement from 100F down to 0F (when it is below 40F the roads are dry 99.9% of the time).
    I'm sure there are points far enough north that make sense for two sets of tires, I'm also sure that there are points far enough south where All Season tires wear too fast due to the heat/road temps.
    Where I live Winter tires suck, and summer tires suck, I only look at all season tires.
  15. huzz1970
    huzz1970 Member
    Arizona
    We just got the S85 (P32507) two weeks ago. I had a long chat with the S/C tech about the tires, and the strong camber (2 degrees). This is puts a bit of extra pressure on the inside tread portion. There are camber adjusts on the 21 inch rims but not on the 19's (I like the look of more rubber to wheel ratio). We agreed to watch the wear patterns, and discuss at the first rotation. It is possible to add the camber adjustment bolts on the control arms with the 19 inch configuration. We will see. The Primacy tires are really quiet so I have no complaints. We passed 600 miles today, stay tuned for more. Will be trying the Phoenix to LA and back trip on Superchargers at Easter, about 1000 miles total for the 3 day weekend.
  16. tomas
    tomas Only partially psycho
    Chicago/Montecito
    I have these tires in 20" on my MS. I wanted something better than 21s for winter and shoulder seasons, but did not want to go to 19s. I LOVE them and may not go back to summer 21s. Good enough for all but worst winter days, great in rain, less risky with potholes, and reasonably quiet on highway. PS, from tire rack.
  17. yobigd20
    Skaneateles, NY
    No that's not normal. I have 43k miles now on my original OEM goodyears with another 15k in them at least. You have bad alignment. As does everyone else not getting 43k+. I have been very heavy on the pedal too so it has nothing to do with driving style. It's simply bad alignment vs good alignment.
  18. xhawk101
    Saint Petersburg fl
    Thanks for helping!
  19. markb1
    San Diego, CA
    Not sure about that. I went through my Goodyears in 10k miles! And there was no sign of uneven wear.
  20. yobigd20
    Skaneateles, NY
    Uh 10k miles? Definitely bad alignment...
