AMPd
No it’s not, if the dash is blocking your view then you need to sit higher.Well for him he says it did. And until I try it for myself, I’m not going to judge.
And visibility is a combination of hood AND dash.
Pilots seem to be disproportionately represented on this board! Seems lots of you like your Teslas on the ground.Interesting you mention that, since I fly 737's, including the Max.
It's just a little bit more complicated. But still, a few relevant points:
1) Automation overriding human input (i.e., the Software Engineers Know Best mentality);
2) Poorly trained and lightly experienced pilots; and
3) Faulty system design relying on only one channel (air data source).
Throw poor maintenance into the mix, the stage was set.
Essentially, there was a very deeply seeded booby trap, and it took a couple of real boobies to find it. Absolutely shocking that they were even in that area of the performance envelope in VMC conditions.
Come to think of it, Tesla's FSD has already handed out at least one Darwin Award:
Apple engineer killed in 2018 Tesla crash had complained about Autopilot
It remains true that any system has points of failure. After all failures do happen and will happen. Poor driver (pilot) training is almost always a part of the mix, but the fewer failures that happen the less likely training will end out mitigating them. We have numerous aviation cases in which superb pilot skills overcame design or mechanical flaws. In automobiles the general tendency is just as it is with aircraft. In normal use who would not want anti-skid brakes, traction control etc. Still, always, the root of many serious problems is design without regard to normal use. That is the case with software, operating system of any kind, safety procedures and so on.Interesting you mention that, since I fly 737's, including the Max.
Video in post #581 misses at least two other notable exterior design changes. Fixed triangular front side window now replaced with a blank filler, and new rocker panel with the lower chrome strip under the doors removed. That makes just about every one of the exterior changes undesirable - for me, at least.
A friend commented “The refresh makes the Model S look much more generic, more like a Honda Accord”.
And hopefully a fix for the wind noise that comes through there.I think the blank filler for the triangle window is awesome - to me it is a reasonable preparation for putting the e-mirrors in that position!
They did, they just happened to have 346 people aboard 2 different jets when it happened (see: 737 MAX MCAS)
And water...And hopefully a fix for the wind noise that comes through there.
That's not test drive material though - it's whether you like or want those features.It’s not the drive quality I am concerned with. It is:
Steering wheel dynamics
Look of the completely redesigned interior
Control of forward/reverse
Turn signal/High beams/EVERYTHING that was once controlled tactically is now through automation or capacitive touch. That’s vastly different.
New seat comfort
New Air Conditioning and associated ventless distribution
GUI of the new MCU
The list goes on and on. When a car can hit 60 in under 2 seconds and rides on an air suspension with Active Noise Reduction, the least of my concerns is how it drives.
Based on history I’d say the prices will either drop quickly within a month of first deliveries, or remain unchanged for at least 2 years.
The current pricing is very similar to the pricing of the 2016 Models.
Well you gotta be able to see the road lolMaybe he doesn’t WANT to sit higher.
Actually the larger the car, the easier to make lower Cd. Just don't forget to multiply it on frontal area afterwards.The new Model S has a Cd of 0.208
That is just amazing for a large sedan
Re: Steering - Is the round steering wheel an option, or is Yoke steering the only steering available.
I had this question too, since my reservation details has Yoke Steering on the list of choices, along with Red color, White interior, etc. I checked with my sales advisor on this. No, there is no option besides Yoke at this time. She acknowledged that this is the #1 question people have about the refresh. They are offering people test drives of the new steering once they get one in their shop.
The round steering wheel image was found in the Tesla site code implying that they had developed a plan B for NHTSA.
Visibility of the dash? Not being blocked by the wheel?No it’s not, if the dash is blocking your view then you need to sit higher.
The car knows you are in a roundabout. You blink to exit. Car could do so even if you miss, swipe, hit, ... think about... the buttonI can imagen it beeing problematic in roundabouts
