I got a 2023 M3 standard range, build date 4/23/23 bought 4/25/23, Made in fremont, which ended up being the second car due to first one having trunk misalignment and they said it was "In spec".
Upon delivery, only issue I noticed on the second vehicle was the steering alignment was off, easily felt as a TOE issue. I made a request for service within the 100 mile window..
4/27 I installed a swivel screen mount, everything was operational.
4/28 at around 11pm, the cars software finally updated to most recent version. As far as i can tell, everything was still operational.
4/29 i took car in for steering alignment. (and it is still not right but better than what it was.)
picked up the car at about 3pm, and noticed later in the evening the left headlight would not turn off and turn signal in that light not operating, and eventually the wipers stopped operating as well (stalk or touchscreen) I scheduled service for 5/3.
5/3 mobile tech came out to reinstall firmware and it failed 2x. tried to troubleshoot headlight not powering off, replaced headlight, did a 12v reset 3 times, and discovered the reason why FW wont reinstall is due to CAN communication errors that popped up.
Service scheduled for 5/5.
1. ill update the results here from service
2. has anyone had this issue or see this issue?
tech seems to think it might be wiring, or the front BCM. would the swivel screen installation have anything to do with this? or is the monitor just a receiver unit and has nothing to do with the main computer and BCM communications?
