New 70, comes with a 75 (disabled) would 100% charge ~ 93% charge
blueguse
10
19
Boynton Beach, Fl
We all know to help retain the life of the battery we must sacrifice range on daily charge to 90%. If the new Model S 70 is "really" a 75, would charing the battery to 100% really equal 93%? My question isn't if I should change to 100% regardless, just curious about how the artificial lowering of the battery capacity really limits the battery capacity.
70 kw * 90% = 63 kw
75 kw * 90% = 67.5 kw
75kw * 93% ~ 70 kw
(75 kw * 90%) / 70 kw = 96%
Therefore a 96% charge of a 70 kw (really a 75) is equivalent to a 90% charge of a 75 kw.
The hardware should still balance the cells regardless of max capacity and if max capacity is actually higher than the amount you are "allowed" to charge there should be extra room for the cells to balance.
Any thoughts?
Again, this isn't a question of IF people should charge their new Model S 70 to 96% just more a question about the physics.
Reactions: Eugene Ash
Rockster
3,007
4,611
McKinney, TX
This is much the same conversation that surrounded the 40kWh battery that was really a 60 inside. The consensus seems to be yes, there's a benefit to having the untapped overhead for the reasons you suggest.
gaswalla
Model S,3,X.. CT with Austin delivery
Sep 23, 2012
3,250
3,520
San Diego
Yes, this is the reason I see no point in going for the upgrade... You are getting to charge to 100 percent daily for free and without worry.
Also, the 40s had issues with battery balancing since 40kwh is only 2/3 of the total battery capacity. In this case, 70kwh is over ninety percent of the he total capacity, and balancing issues shouldn't be a problem and battery health should be maintained.
