Based on @gaswalla's post below yours, I think you're right.Maybe it is a remanufactured pack - a 100 pack w/o the two stacked modules at the front.
Since you have a Ludicrous car this is encouraging!
How does your regen performance feel at assorted temperatures? That is another aspect of lithium plating that will need to be long term managed from day one to maintain long term health.
Max discharge doesn't seem to add up for a P85DL. I see you're only at 75%, but I'd be curious to see what you're max output is. It needs to be able to achieve over the normal ~1500A, am I missing something?
There was another post on this and the math makes sense. So @ 400V and 1500 amps, which is what we know the 85 pack could do, we have 600 kW out of the pack max. I get that there is voltage sag under load and we are never really at the full 400V but working with theoretical maxes comparatively still highlights the new battery has the power. The new P100D cars can get 1735 amps max out of their packs and since max current is based on number of cells in parallel and max C rate then we can assume the same would apply to the new 350V pack. So @ 350V and 1735 amps we can get 607 KW theoretically.
I agree with you and the math if that is what the car/cabling/contactor, etc can all handle. However, I was looking at the screenshot he posted above and max discharge and amps show differently.
I posted the battery data.. it's from my OG Model S --- simple 85 from 2012
View attachment 501277 Done charging! Confirmed 289 miles rated as the Tesla app suggested previously!
Hi @Roadrat11s, I have multiple Teslas and have had this issue as you describe. I did a lot of reading, and on my recent trip through AZ, I utilized the 'wet towel on the supercharger handle' method with huge success (maintain high kw charging rates). Basically, V1 and V2 chargers reduce the charge rate to keep the handle from getting too hot. Putting a wet towel (add an ice pack if you really want to see a difference) keeps the handle cool and keeps the charge rate elevated.
You sure the handle isn't overheating? You can try the wet towel on the Supercharger handle trick to help rule that out. https://twitter.com/Out_of_Spec/status/1282464387819876352I did a few more supercharge visits over the weekend and still have a reduction, seemingly from thermal issues, after 4 minutes of 112 kw charging. When it is 90F out it goes down to 70kw and when it is 60-70F only down to 90kw, then when it hit normal taper charges as expected. I have never seen a charge curve with 2 flat spots unless there was an issue. Was wondering if any of the other people that have this pack have logged any supercharger data, like RM/SOC versus charge rate? I have a service appointment Thursday and would appreciate any data to help my case as of course Tesla is currently saying " no error so everything is fine". Thanks in advance.
