Hi All,
So I've noticed my car bottom scraping in places it never used to, this has started happening since they changed the way the air suspension heights are set. After watching that screen when driving I can see why it happens.
If I set it to 'Very High' then it stays there until the car goes over 24kmh (15Mph), but here is the problem, it then defaults to 'Standard' height after that, not 'High'. What I am finding is if you are navigating through shopping centre car parks and you raise the car to 'Very High' to get over a speed bump then unless you keep the car under the max speed for 'Very High' then the next speed hump I end up scraping because it has auto dropped to 'Standard'.
I don't get why they would transition from 'Very High' to 'Standard' and not from 'Very High' to 'High'.
This has become a total pain as I have to check prior to every speed hump what the thing is doing now.
I also feel they may have lowered the max speed of the 'Very High' threshold as I never used to have to reset it once entering a shopping centre car park, maybe this is the only change that is causing the problems for me.
Has anyone else noticed the operational change on the heights and increased scraping?
