I find it interesting that with the 3, the AWD flavors get less range, whereas with the S, the AWD models got slightly more range, despite the extra weight.
The general attribution for the increased range was that the front motors on the S were geared slightly taller, and the car had the ability to "torque sleep" the rear motor when cruising, in effect shifting to the motor operating in a better efficiency range at higher speeds.
I wonder what is different with the 3. A couple of thoughts:
1) The motors are not geared differently if they are using the same gear reduction unit on both ends despite being an AC induction in the front. This may be being done for economies of scale from a manufacturing perspective.
2) The SWRPM motors don't have the same back-EMF characteristics such that the RPM shift accomplished by taller gearing didn't make that big of an impact.
3) It may not be practical to "torque sleep" a switched-reluctance permanent magnet (SWRPM) motor. Given that motors with a PM component tend to "cog" when freewheeling, this may prevent being able to do this smoothly. If so, this might prevent completely sleeping the rear motor. The front AC induction unit that may be the only one that can sleep.
I've seen some discussion that Tesla getting the power electronics capable of shaping the waveform to operate use a SWRPM motor in an automotive application was a significant feat. I've also heard someone say that when a model 3 is coasting without power, you can feel a little cogging.
I suspect that #1 is not as likely, and it may be some combination of 2 & 3...
