cali8484
I'm not sure if what you meant was that the install is simple with an interlock; or if you meant the install could be done without a permit.
If it's the former, I don't think you can use an interlock kit with your Ford EV charger. Because on normal days, owners want to actually be able to charge their truck. The interlock kit would typically be applied so the breaker to the "generator" was locked in the open position if the breaker from the utility was closed. This isn't really what people want for normal operation of something integrated with their home since they'll want both the utility breaker and EV charger breaker to be closed.
If you meant the latter... in Contra Costa County, Alameda County, Sonoma County, and other areas near me... generators that connect to the home need to be permitted. In some cities, the plans even need to be reviewed before a permit is granted (so no e-permitting). So even the simple stuff may not be so simple for many buyers.
Sure, you can charge it with regular J1772 EVSE and plug in the 120V/240V power output into a power inlet backed by transfer switch/interlock kit when you want to use it for backup power just a backup generator. Permitting is covered by the "local code requirements" I mentioned.
