I believe both the Kia Soul EV and Hyundai Ioniq have charge rates nearing or exceeding 2C. There may be others as well, I've not really tracked them that closely.
Those are the onboard AC chargers.According to plugincars.com
Tesla Model S
Hyundai Ioniq
Kia Soul EV
Charging rates:
Tesla MS - 10 kW
Kia Soul - 6.6 kW
Ioniq - 7 kW
I'm not sure where these numbers are coming from. JB Straubel has been quoted as saying the energy density improvement from original Model S packs* to Model 3 is ~30%.
*Not necessarily the more recent 2014 packs with an already-improved silicon anode chemistry which represented a ~6-7% jump.
No offense, but between your take and JB's...I'm going with JB...30% gravimetric energy density improvement? Not likely.
Don't forget that the original Model S pack, packed, 85kWh which really was more like 81 or so. +30% is then how much?30% gravimetric energy density improvement? Not likely.
Any information or speculation on when the new 2170 batteries will be available in the Model S? Waiting on upgrading my 2013 Model S and thought I would wait on new batteries (first it was dual motors, then self driving hardware, now battery upgrades). Anyway, expecting lower weight, improved performance, maybe more range, definitely more efficient. Plus, I hate buying old technology and am quite happy with my older S at the moment.
JB's comment was pretty vague and seemed to imply pack level specific energy from the original Model S design to the Model 3 design. The 30% remark would then include the silicon anode step change and the 100 kWh pack change. The original specific energy density at the pack level was roughly 148 Wh/kg. Now, it's around 175 to 180 Wh/kg. That's already 20% or more. One more step change in battery chemistry, as well as some minor differences because of the form factor change and we're at the 30%, or 190-200 Wh/kg.
The C rates being referring to above are the DC fast charge rates, IE the Ionic charging it's 28kWH pack at a peak of 100kW for a C rate of >3.
OK, that makes sense there are different charge rates for AC and DC. Tesla claims a 120kW DC charge rate so I seems like it still beats out the Ioniq by a 20 kW, unless I am misunderstanding something.... again
I heard word from CEC anonymously that they are testing much higher than what Tesla is doing,something like 350kW or so. but I just heard this on a teleconference for FCEVs, no verification or company names sadly...maybe Tesla? :>That sounds interesting.... which cars have "significantly higher charge rates than Tesla", I thought Tesla was the leader in fast charging.
Would Model 3 then feature a totally different super fast charging chemistry for its 2170 cells? That might kill density improvement expectations of the latest 18650 cells.
If the 2170's to be used for cars are all going to be fast charging, with compromise on energy density, that might explain 100kWh to remain the biggest.How the new cells will be made or optimized for is all speculation. Ideally they are cheap, last very long, have a high capacity, charge faster, have higher efficiency, are easy to manufacture, use less expensive materials, allow high discharge rates, ...
The list is what they should be is long. Knowing what Tesla has done with the Model S/X batteries so far shows they are keeping everything on the safe side. Temperature, charge & discharge rate, limiting lowest point of discharge, limiting power (in certain conditions), all these things are kept within pretty safe conditions. It's clear they want these batteries to last a long time.
