CyberDutchie
I can't imagine this happening, due to engineering challenges. The packs have to be temperature controlled (heating/cooling), have to be designed to withstand various impacts and have to be designed to protect passengers from a run-away reaction. It is not a trivial matter to add more battery modules, and if you include all the supporting infrastructure, the actual weight of the battery pack would be significant, which has an adverse effect on range. Its usually best to keep the design as simple as possible.
That's probably true. The pack would have to be modified to be suitable for non-stationary use, and have the ability to DC to DC charge the main car battery. As for add weight, though, if you have to give up a couple of third row seats, that's about 400lbs to pay with.
- - - Updated - - -
And there is additional problem of balancing both packs. If onboard battery had lower voltage (lower SOC) it would drain the AddOn batteries or vice-versa. There would need to be a balancing device that would limit this surge current not to damage the batteries.
The add-on battery would be used to (quick) charge the main battery. As a backup pack, like the ones you bring with you to charge your phone. Not directly drawing power from it while driving.
