AgreeThe old and new "comfort" suspension are crappy in different ways.
Old suspension is way too harsh especially large bumps. The new suspension is less harsh on the biggest bumps, but bouncy/floaty at lower speeds.
That’s not true at all. The spring rates and damper rates will translate exactly into how the suspension will feel.Suspension is something entirely subjective.
It's not something many know anything about how it works.
And few have experience with upper end car suspensions, so have limited basis to compare with.
Did they move to progressive springs?The old and new "comfort" suspension are crappy in different ways.
please state what part(s) of the post isn't trueThat’s not true at all. The spring rates and damper rates will translate exactly into how the suspension will feel.
How about the bushings? They play a very important role in this. Have they been updated too?
Control arm bushings.What bushings? Nobody has mentioned bushings that have been updated to my knowledge.
bushing upgrades from the stock rubber / polyurethane will mostly just increase NVH transmitted to the interior.Control arm bushings.
ummmm You could upgrade to more luxurious bushings too.bushing upgrades from the stock rubber / polyurethane will mostly just increase NVH transmitted to the interior.
street driving isn't track driving.
you're not looking for continuous precision under the heavy loads generated by driving at limits; you're looking for smoother / quieter street behavior.
The MYP you rented was a 2022 correct? Sad to hear this but I believe it. I'm really considering updating mine to the new "F" revision parts soon. It's inexpensive (in the grand scheme) and easy to swap. If my friend's 2023 doesn't clunk or knock when I test drive it soon, I think I'm definitely going to do it.The P and the LR are different cars. I have owned both. The LR was harsh over bumps but was very smooth riding otherwise. The P transmits every road imperfections into the cabin and through the wheel...even with 19s on it. It's more harsh than it should be IMO. In fact I had a clunk the developed in the front after a few thousand miles, they replaced strut and it went away for another few thousand, now its back. They said its characteristic on the YP and I rented another YP 544xxx VIN and it makes exactly the same noise over small to med bumps.
It's interesting because I always thought the suspension were the same except for a slightly lower ride height.
PSA:. To anyone who wants max ride comfort in the Y but also wants max performance....your best going with a LR and then getting the acceleration boost.
Yes its a 2022 Built 09/2022 VIN is 544xxx has 7,600 miles. My May 22 build MYP VIN 446xxx has the same part numbers as above. It didn't start making noise until after about 3800 miles. Strut was replaced, almost same mileage started making the noise again. Tesla said it was characteristic of the MYP, but they spent about 25 days on it and I took it in 6 times! That's why I rented this MYP to see if it was the same and it isThe MYP you rented was a 2022 correct? Sad to hear this but I believe it. I'm really considering updating mine to the new "F" revision parts soon. It's inexpensive (in the grand scheme) and easy to swap. If my friend's 2023 doesn't clunk or knock when I test drive it soon, I think I'm definitely going to do it.
I’m also wondering if a fix for the clunking was implemented in the Rev. F struts, even if they don’t necessarily make it that much more comfortable.
I am not sure but the new "comfort" suspension appears to have both pros and cons when compared to the old one.Did they move to progressive springs?
not available for Teslaummmm You could upgrade to more luxurious bushings too.
My original query was “Did the comfort suspension also include new bushings too?” Sorry if I was not clear.not available for Tesla
Are the comfort dampers still noisy though? My LR was smooth as silk driving down the road. I should have known the P would transmit more NVH into the cabin. The crazy thing about it is that for the first few thousand miles the car rides different. Once the suspension settles in the ride is more harsh.Just returned from a back-to-back drive. Definite improvement noticed in my friend's 2023 MYP, over my 2022 MYP. We have bad, heaved roads in Upstate NY and I could tell the difference right away. 2023 has more of a damped, BMW feeling. Still bad, but not *as* bad.
If you don't notice a difference between '22 and '23 suspension, come to New York. There is a section of road I test on that has continuous bumps for about 20 seconds, and it would knock my head/body around a bit. The '23 controlled it much better and the car wasn't shaking back and forth as much. But it wasn't "comfortable" by any means like it is in our Hyundai.
Now that I know I'm going to change my suspension, I just have to consider these or the Tein EnduraPro Plus shock kit. They're both the same price... But Tein goes even softer.
His car only had 580 miles on it, so no, no noise yet. I listened for that. And yeah, his car may get worse once a few thousand miles are on it. It drove really nicely compared to mine with 6500 miles.Are the comfort dampers still noisy though? My LR was smooth as silk driving down the road. I should have known the P would transmit more NVH into the cabin. The crazy thing about it is that for the first few thousand miles the car rides different. Once the suspension settles in the ride is more harsh.
Tein are adjustable.Just returned from a back-to-back drive. Definite improvement noticed in my friend's 2023 MYP, over my 2022 MYP. We have bad, heaved roads in Upstate NY and I could tell the difference right away. 2023 has more of a damped, BMW feeling. Still bad, but not *as* bad.
