Heh, I had to think about it for a few seconds too.I googled "ice poison" with no luck. What is this?
If I had a chance to build my garage again I would definitely design enough room between cars that the doors can be open fully without worrying about hitting another car!
I am having a new place built as well, and just picked our options.
My option for the garage outlet was 220v 60 amp outlet. Will this work for my car? They didn't have a pic of the socket. Also, shouldn't it be 240v? I do have an HPWC at my current place, but that was because it was only 30amp I could get. Should I have the 220v 60amp installed by the builder for $750? Or just have an electrician run me an outlet for a 14-50 outlet? The panel is already in the garage so it would not be a far run. Ideally I'd like to sell my HPWC to fund the new outlet.
Thoughts?
A 60A outlet is almost useless. Thete is no UMC adapter for a 60A outlet because they're so rare. If you want a 60A circuit so you can charge at 48A, wire your HPWC to it and forget about the outlet. Or just have them wire a 50A circuit with 14-50 outlet. And yes it's 240V not 220.I am having a new place built as well, and just picked our options.
Thoughts?
Thoughts?
As long as you're paying for 60A wiring and breaker, it doesn't make sense to me to pay to substitute a 50A breaker and outlet if you already have a HPWC. Just have the HPWC hard wired into that circuit and charge at 48A. How much do you think you can get for a used HPWC? They're only $500 new.Thanks all! Unfortunately with the builder my only options was a 20amp outlet and 60amp outlet at 220v. This didn't make sense to me.
I think I will just have my electrician wire a 14-50 outlet for me after the fact. With the panel already in the garage, it would be a very short run. And this way I know I am getting the proper outlet and voltage for my car. With my UMC then I will get more than sufficient charging speed for my needs, and can sell my HPWC.
My issue is with them saying it is 220v. I don't want to pay them to do a 60amp at 220v, and then realize I have to redo a new outlet anyway at 240v. I'd do 60amp if it was at 220v. But they are also running me an outlet. So then I'd have to pay additional to get my HPWC wired into it as well by an electrician. So why pay $750 for the outlet then more for the electrician to come wire it when I could just have him do it right from the start?As long as you're paying for 60A wiring and breaker, it doesn't make sense to me to pay to substitute a 50A breaker and outlet if you already have a HPWC. Just have the HPWC hard wired into that circuit and charge at 48A. How much do you think you can get for a used HPWC? They're only $500 new.
The 220V is just a colloquialism from the old days. It's like people talking about 110 outlets when they're actually 120. The power company sends approx. 240V to your house. The breaker, wiring, outlet he will use are all for 240V as there is no such thing as different ones for 220V (actually all that mattters for the circuit is the amps anyway). To do it right the first time, as long as it seems you've paid for a 60A circuit already, just forget the outlet and have the electrician install the HPWC hard wired on that circuit.My issue is with them saying it is 220v. I don't want to pay them to do a 60amp at 220v, and then realize I have to redo a new outlet anyway at 240v. I'd do 60amp if it was at 220v. But they are also running me an outlet. So then I'd have to pay additional to get my HPWC wired into it as well by an electrician. So why pay $750 for the outlet then more for the electrician to come wire it when I could just have him do it right from the start?
As was already addressed, 120V and 240V are the real values, but 110 and 220 are just leftover old fashioned terms that some people just can't get over using. But I don't get this terribly limited lack of options. A 20A or 60A circuit--that's it? Not even a 30A? 30A is really common for several kinds of things. Anyway, I would probably fight with the builder a bit on this, because it should be pretty easy to spec out what you really want with a 60A circuit for the wall connector. They just need to know: 60A breaker, this gauge of wire (two hots and a ground), connected out to this location on the wall, and I have a wall-mounted appliance to connect to it there. That's pretty straightforward.Unfortunately with the builder my only options was a 20amp outlet and 60amp outlet at 220v.
As long as you know that the electrical panel is in the garage, your plan will work out fine. However, my main panel is on the other side of the house and it would be 5X the cost for me to install my two 50 amp circuits today compared to when the walls were open during construction.Thanks for all the replies. Since i am extremely limited with my builder on my options, I am just opting to get it done by my own electrician after closing. Whatever he suggests, with the 14-50 or the HPWC, I will do.
Thanks again all!
