bollar
Disgruntled Member
Agree. And I did a bad one today. Argh.Rim guards are for bad drivers and the elderly. With that said, I'll likely scrape a curb this week.
I don't think a single unit "o-ring" would make installation any easier and might make it more difficult. The thickness/diameter of the ring itself needs to be at 3/8" and that spec wasn't provided on the Phoenix site.
I hope I haven't encouraged a rush by others to install this on their own Telsas. I'd suggest everybody hold off for a two or three weeks so I can get some experience with this under my belt. I drive about 40 miles a day with some approaching 100 so that should be a good test over a 2-3 week period.
- - - Updated - - -
The problem is that the car and its stance is so large when we're driving for the first time we underestimate where the wheels are when we turn around sharp curbs.
I did all most of the damage to my rims in the first several days and weeks before I was able to get any protection installed. Then a few careless moments resulted in some other damage to the rim protectors and the rims themselves. I'm hoping this solution will protect me from careless moments in the future. I know there will be some.
Any progress on testing? Looks good, but hard to claim it's superior without a test. I'm curious how the glue will hold up in a rashing.
Looks very cool. If this works out, I can certainly see switching over. Though I'd first have to get my rims repaired since half of the reason I have any rim guards now is for cosmetic coverup :redface:
You should use 3M black weatherstrip adhesive, available at any auto parts store. It definitely bonds to rubber.
I've tried it. No luck.
Silicone caulk?? Assume you carefully prepped the surfaces (?Goof-off).
Rubber that dries out can crack and affect sidewall integrity. Are you concerned about the area under the superglue becoming damaged? It seems like after awhile that area would be prone to failure.
That said, I doubt the stock summer tires on the 21"s will last long enough for that to be an issue.
My main concern is that on most tires, for lack of a better phrase, the rubber needs to breathe. You may recall the huge flap years ago when it was proven that ArmorAll's coating was drying out tires, leading to sidewall failures. I'd be less concerned about the glue drying inert than the coating it creates on the tire causing structural changes by blocking the rubber's ability to breathe and absorb water.
I believe this change was occuring over 40-60k miles and several years, if I recall, though, so probably of no consequence to anyone on the stock Continentals. While certainly more catastrophic, a far less likely outcome than curbing your wheels.
