New Feature Request: full regenerative breaking when pressing the break slightly
Should we add Break Activated between Low and Standard
  • Yes, add Break Activated
    Votes: 10 26.3%
  • No, Options are bad and nobody wants this.
    Votes: 28 73.7%
  • Total voters
    38
I was surprised today when I played with my drive settings to find that switching regenerative breaking from low to standard actually affected more than just the pedals.
I would have expected low to mean that if coasts better and standard to be more of a one pedal driving experience.
I suggest we add a third feature of Break Activated, which would be “Low” when no pedals are pressed but “Standard” when the break is pressed slightly.
Thoughts?
Thoughts?
Regen on the brake pedal is a much discussed topic around EVs. My Volt had it and I liked it. HOWEVER, it had one major flaw. If traction was ever felt to be slipping during braking, the brakes went instantly to friction brake mode causing the pedal feel to change dramatically during a braking event. The first time it happened, it felt like the car shot forward for a second before I pressed harder on the pedal. Once I was aware of the phenomenon, it wasn’t as scary, but it was quite alarming the first time.
Now, I suppose a sofisticated enough computer program could apply hydraulic brake pressure to equal the regen pressure in that event, so the pedal feel doesn’t change, but I don’t know that anyone has perfected that yet.
Thoughts?
I agree, this would allow us to reclaim more energy. So normally we can leave the regeneration to low, and when we touch brake strong regen is added. This way we can coast mostly when needed and still reclaim power when we want.
Also, I wish there is even stronger regen option on brake.
I agree. I had a Volt and I like the Tesla system better. The brake pedal is for friction brakes, and has the feel of friction brakes. Not this weird marriage.
This is the way my Prius drives, and the reason why after 141,000 miles on that car I still have 65% of my front brakes and 70% on the rear.
Now that I'm driving my Model 3, I'm getting used to the "one pedal" driving, where it still trips me up sometimes is when the batteries are cold and I'm getting reduced regen capability. But I'm learning!
Thoughts?
Other than not being used to standard regen, there are not many legitimate reasons to switch from standard to low. The main reason to switch, would be because you know the roads are icy and you want to lower the chances of the ABS needing to intervene when braking. This is a lot more important on the RWD trim, since only the rear wheels regen. In that case, when you switch regen to low, you expect the car to let you use the brakes to slow.
Learning to coast using the accelerator is better than using low regen.
I have a Volt and have experienced the issue you describe. When it happens, it actually feels like you are speeding up (even though you aren't). Not sure about the Gen 2 Volt, but the Bolt's regen braking programming greatly improved this issue. When going over hard bumps while regen braking, it doesn't "break" regen braking like my '12 Volt does. Or if it does, it's only for a split second and you can barely even notice it.
The standard regen is the maximum regen possible. When you take your foot of the go pedal, it starts regening and the brake pedal only actuates the mechanical brakes. The brake pedal is not computerized like it is in hybrids. The car can put the mechanical brakes on also.
Tesla has designed the Regen. well. They do not want it to be too strong or it will cause problems on ice and snow.
They want the driver to have their foot stop the car in the last few feet, so the driver will be in control, not the car.
So many people are about optimizing the regeneration, but fail to realize that very little current will flow to the battery at low speeds. The vast majority will be used to bring the car down to walking speed.
Tesla also wants the physical brakes (breaks) to be exercised just a bit on most every drive. It keeps the seals and surfaces of the brakes operational. It dries off the rotors if wet and scrubbs off the typical dust of rust that happens when they are not used for some time.
I think their current system is genius. I am always amazed and caught out when I charge to 100% and the regen is temporarily unavailable. Makes me appreciate how wonderful regen braking is.
I imagine that even with full autopilot the computer will continue to press the physical brakes for the final stopping.
An AC induction motor needs a supply of power to the motor in order to engage regeneration. That's fine, because it regenerates more energy than it has to expend to energize the magnetic field. I assume that the 6mph cutoff on regen is probably the point where it starts to break even and resorts to the friction brakes instead.
Reactions: Santa Claws
It is my understanding, from seeing some previous posts, that the Tesla brakes are just brakes. While fly by wire, their wire doesn't seem to connect to the regen. In my Leafs, the brakes were definitely controlling regen with very seamless transition from regen to physical brakes. I think that it is a significantly better implementation than the Tesla.
Also in the Leaf, there are two levels of regen, that can be changed on the fly (shift into drive and get standard regen, shift again and you get enhanced regen, the "B" mode). This provides what I believe to be better efficiency in a number of situations. The first is when coming to a stop, there are a number of situations where coasting is more efficient than braking and then regenerating. And when on the Interstate, or higher speeds, it is again more efficient to coast than brake and regen. In the Tesla, you have to masterfully modulate the accelerator to do so, in the Leaf, I release the accelerator.
I agree, I really would wish that Tesla would allow the brakes to control regen. I would also like to have the ability to change regen levels dependent on driving conditions and not go through multiple menus to get there.
I'd prefer if there was a mode of basically no regenerative braking, and the brake seamlessly handled the difference between regenerative and friction braking. Then there is a very clear purpose to the pedals. One makes you go faster. One makes you slow down. Want to go the same speed? Don't push either of them. I find it hard on my ankles to how the accelerator pedal at a consistent location for long periods of time. Of course I could use autopilot, but with this system you basically get it for free and I suspect more intuitively. I suppose you have an issue if someone falls asleep at the wheel and the car never slows down, but that is probably a problem either way...
I don't get these comments about regenerative braking being a problem in snow or ice. Braking is braking. I would imagine the car would be able to do an even better job limiting braking during slip when it was regeneratively braking than using the actual friction brakes. Maybe a problem where people freak out and instinctively take their foot completely off the accelerator instead of controlling the deceleration?
Love Tesla's implementation of regen. It offers the necessary insight for the most efficient driving. Specifically, the current system helps the driver to use the least possible friction brakes if they want to because it is totally obvious where regen ends and friction begins.
Now, having said that, I would personally love an option to have the vehicle apply light friction brakes below 5 MPH because I am going to probably have to do it and I want one pedal driving. EAP has no problem applying the brakes for me below 5 MPH ;)
