New Home Charger Installations & DNO EV Applications
Discussion in 'The UK and Ireland' started by LEE3, Aug 21, 2019.
  1. LEE3
    LEE3 Member
    Broxbourne
    So I had a charger installed at home a few weeks ago and the electrician had recently been on ‘the course’ where he learned that anyone that has a maximum electrical demand in excess of 60 amps has to effectively apply to the ENA for approval to use the charger so that the supply / capacity can be appropriately assessed.
    ENA - Electric Vehicles and Heat Pumps
    He went round and switched all the main appliances on in the house which reached around 50 amps and this was obviously without the car charging as it was yet to arrive. So he then suggested that as the car charging will nudge the output over 60 amps I would need to submit the form.
    Since then I have purchased an energy monitor and even with the car charging I cannot make this thing reach anywhere near the 60 amp mark. On average so far it’s maybe 30 amps.
    Now of course I could go round switching on two ovens two kettles two tumble dryers all the lights and the car but the reality is that is not normal usage. So I am hesitant to engage with UK power networks at this stage and have the usual painful dealings with them (big previous issue with relocating mains cables costing £10000+) when I can effectively manage my output to never reach this 60 amp limit. My concern is Power Networks will use the opportunity to make upgrades to the substation and try to charge me for it. (Private road with old infrastructure recently taken over by Power Networks).
    So is there anyone else who has made this application with any complications?
  2. kevuwk
    kevuwk Member
    UK
    I’m currently talking to my DNO and they say I can get an 80a fuse free of charge if it is for EV charging. If you think you need the 80a then it may be worth enquiring but the 100a fuse usually requires some wiring and fuse holder upgrades
  3. NorfolkMustard
    Blighty
    Yeah, it’ll probably just be a fuse swap in the incommer, get them to install an isolator switch while they’re there to make it worthwhile if they do charge.
  4. VanillaAir_UK
    VanillaAir_UK L plates
    Surrey, England, UK
    Is the 60A limit because you have a 60A fuse or will it also apply to those with 80A and 100A fuses?
    Is the 60A limit based upon the diversity calculation?
    I've got a 100A fuse and can show my max load during the day as I log it on 5 minute basis 24/7/365
  5. LEE3
    LEE3 Member
    Broxbourne
    I have an 100 amp fuse. Does this make any difference as I thought it’s the providers desire to be told of demands on the network rather than the capacity at the house?
  6. NorfolkMustard
    Blighty
    Hadn’t heard that. If that were the case you think they’d have fitted 60amp main fuses so they have to be involved in increases, rather than relying on being notified.
  7. interbear
    interbear Member
    Monmouthshire, UK
    I was told exactly the same by Western Power when I enquired. They swapped out the existing 60a fuse for a 80a fuse free of charge and told me that it would be more than enough for our household + the EV charger. A 100a fuse would have required (1) Western Power to change the fuse holder, estimate at £150ish o_O and (2) the electricity supplier to upgrade the meter tails (cables) from 16mm to 25mm, which is apparently needed for a 100a fuse. I actually had EDF do the latter anyway (it was free) just in case I need to upgrade to a 100a fuse in future. Which I doubt will be necessary.
  8. kevuwk
    kevuwk Member
    UK
    I wasn't sure what fuse I had and neither did they. One of their engineers has just been and checked and there is a 100a fuse so I can finally start looking at getting a charging point installed.
  9. LEE3
    LEE3 Member
    Broxbourne
    So the results of communicating with the DNO appears to relate more to the capacity of the premises and not their own infrastructure.
  10. Fullerene
    Fullerene Member
    Dorset, UK
    This is ridiculous and unrepresentative. I have lots of sockets in my house, I've got 3 large Distribution boxes in the garage and a further one in the shed, previous owner was trying to future proof or something... If I put a 3kW heater on each socket the load would be ridiculous - but on a very rare occasion my worst case is oven & dishwasher & kettle. which is about 7-8 kW, I can accurately count the amount of times this has happened in the past few years on one hand, I have a home rolled energy monitor and graph this sort of thing to death.
    As far as I know the DNO needs to be informed as it's their duty to have adequate infrastructure, part of which is paid by a levy from all of our electricity bills.
    What staggers me is choosing the car is really simple, choosing the EVSE was the hardest part.
  11. VanillaAir_UK
    Surrey, England, UK
    I looked in the document posted and the calculation can be done on known usage (I think it is total usage rather than individual loads) or using a diversity calculation. So going around and turning everything on and measuring the output is probably not the most sympathetic method to do it.
    I have 5 minute load readings going back quite a few years which would hopefully satisfy the final paragraph.
