  • The final cut of TMC Podcast #34 is available now with topics timestamped. We covered Tesla's rollercoaster prices, Toyota pushing junk science, Mike's new Model 3, Optimizing track mode for snow driving, FSD V11 apparently coming by the end of this week, and more. You can watch and check out the chat replay on YouTube.
New Michelin PS4s put on with updated T2 rating
WilliamG
Hinge Fanatic
Apr 20, 2019
7,112
11,049
Seattle, WA
Good to know. Suspect it will never be enabled and might even be a Tesla-specific version without the hardware completely (I haven’t had the chance to look at mine but assume it’s the same as that - definitely T2). Until someone takes a tire off a new S we likely won’t know if the hardware is there.
Based on the sensor images Michelin has shared. The module is rather small and looks to be cast into the actual carcass of the tire. Pirelli touches on the engineering challenge of making a module that could withstand over 3500 G’s of shock but doesn’t explain specifics. Either way I’m sure it’s the same vendor supplying the underlying tech/module. They are German based on the markings.
Tesla has already transitioned to BLE tpms so it’s likely just software that needs to be updated. They don’t need to capture/use all the information provided and can just use tire pressure at first.
The transition to using the other information is just a matter of time, but this is Tesla. They both do things faster than anyone else, and also seem to never to get to some things.
The T2 tires DO have the bluetooth module. I just patched a hole in my tire and saw the BT device.. It is cast along the center of the inner tire.. There is also foam. I thought in my previous post that it didnt have them, but I stand corrected. There is a QR code on the back you can scan I guess.. Too late for me to do all 4, but yes these tires have that tech..
Reactions: WilliamG
WilliamG
Hinge Fanatic
Apr 20, 2019
7,112
11,049
Seattle, WA
Very interesting. Shame we’re not likely to get any use out of them.
WilliamG
Hinge Fanatic
Apr 20, 2019
7,112
11,049
Seattle, WA
Just in case any of us "Legacy" S folks are lurking around this thread, this appears to only be relevant to the 2022+, not for us oldies.
OP talked about these being significantly quieter - I'm curious if that's true, or just so much quieter than the worn out old tires.
Naaaaa. I’ve had both types of tires, and was in fact driving a 2021 all weekend before back to my 2022 with the T2 and there’s no difference that I saw.
