Like it's been said above, it was redesigned because a lot of NEMA 14-50s are installed on 40amp outlets. In Canada, you can only draw 32A max anyways due to their electrical code.
The part I'm puzzled about now is that I'm 90% sure my car has charged at 72 amps from a destination charger which is just an HPWC, no? So why can't I get 72 amps at home? I know that is the default number in the limit adjustment in the car. I was testing a local J-1772 unit once and it started out charging at some current but with a 72 amp limit. After a while the limit adjusted down to about the charge rate.
You can. I have an HPWC on a 100 amp breaker and my 100D charges at 72 amps without any problems.
It's odd that the docs seem to not show this possibility. They list charging rates for the X and S and they stop increasing the MPH at a 60 amp circuit I believe (48 amp to the car).
Because they are only showing charge rates for current cars? It get a lot more complicated if they start to include older X's and post-facelift S's with 72A chargers, and pre-facelift S's with single and dual chargers (40A/80A).It's odd that the docs seem to not show this possibility. They list charging rates for the X and S and they stop increasing the MPH at a 60 amp circuit I believe (48 amp to the car).
Yes, until very recently the 75's had a 48A charger and the 100's had a 72A charger. They appear to have dropped the 100's down to a 48A charger very recently - like maybe a month or two ago - but I wasn't paying attention.Older as in 2018? My X seems to charge at 72 amps.
Yes, that's why I chuckle a little at people overbuilding their home charging setups because they say they need to "future proof" for electric cars years from now that will have super high power home AC charging. Riiiight. Tesla has shown their constant tendency to be downward over time in that regard. The highest charging they offered used to be 80A, then 72A, and now 48A.Yes, until very recently the 75's had a 48A charger and the 100's had a 72A charger. They appear to have dropped the 100's down to a 48A charger very recently - like maybe a month or two ago - but I wasn't paying attention.
Why on earth would they do that? Some kind of component consolidation? Seems rather pointless otherwise. I'm glad I got one that charges at 72 amps. It makes stopping at a destination charger much less painful to get a few miles to reach a Supercharger.
...at home.Probably because most people are not going to need 72A charging.
...at home.
We've been over this in other threads, but there are still gaps in the Supercharger network, where there are high amp wall connectors filling the need, and having a higher power charger in the car makes that much better. I guess that is still "most people" because not everyone lives near these routes that are off the Supercharger paths.
Probably because most people are not going to need 72A charging. The majority of L2 public chargers in the country max out at 30A. I've only seen 80A L2 chargers in Canada. When i installed my wall connector, i only did a 60A circuit (48A charging) because NEC codes require a separate disconnect switch if you do above 60A, which would've just made installation expensive and cumbersome only for a meager 10-15mi/hr more in charging rate.
still "most people" since 99% of the US population lives within 150 miles of a supercharger.
Tesla says 99% of the US population is now within 150 miles of a Supercharger
I didn't read this entire thread.
The mobile charger Gen 2 (aka UMC) only charges to a maximum of 32 Amps - The Gen 1 charger from older MX's & MS's was 40 Amps
The part that bugs me is the only good way to get more than 32 amps at home is to spring for a *much* more expensive HPWC and then only get 48 amps... if that is correct. I think on my car I will get 72 amps and I'm going to test that this week when I drive up to Frederick, MD. I'll be stopping at the newly opened Haymarket, VA Supercharger going up and back and also the destination charger in Leesburg, VA just to test the max charging rate.
