New Model X squeaky brakes...normal?
Discussion in 'Model X: Driving Dynamics' started by EV Family, May 25, 2016.
  1. EV Family
    EV Family Like Tesla
    Georgia
    Have had our MX for 7 days and logged more than 500 miles but our brakes are terribly squeaky. Are other X owners experiencing this same thing? The car gets plenty of attention as it is, turning heads for squeaking makes me squeal. ;-)
  2. CaliX
    CaliX Member
    Los Angeles
    Can be when I put my S regen in low regen the will squeak sometimes, when I put it back to high regen it goes away. My X so far is the same way.
  3. GottaGetRidOfICE
    Boston
    #3 GottaGetRidOfICE, May 28, 2016
    My X's brakes squeaked for a long time, but it eventually went away. I use standard regen, and pride myself on seldom using "old fashioned" brakes, so I think that's what happened. All fine now.
  4. vandacca
    vandacca ReActive Member
    Hamilton
    It's very common for Tesla owner's brakes to get a layer of rust on them, due to their low usage patterns. Some SC suggest to hit the brakes hard a few times to wear off the oxide layer off.
  5. Softwizard
    Softwizard Member
    Keller, TX
    Yes mine started squeeking after 500 miles and still squeek with 2000 miles on it
  6. trmmcd
    trmmcd Member
    Arlington, MA
    Mine squeaked initially but after 1000 miles have quieted down.
  7. ssq
    ssq Member
    New brakes would do that sometimes as the pads "carve in and cure" on the rotors. Or it could be that there is water/moisture in between the pads and rotors. Did you see this after washing the car or perhaps after rain?
  8. deonb
    deonb Supporting Member
    Redmond, WA
    My Model S squeeked for about 5000 miles, no matter how many hard stops I tried.
    It's been quite ever since, but it took a while.
  9. Blastphemy
    Blastphemy Member
    Los Angeles, CA
    Yes, our Model X squealed at stops for the first month or so, but eventually stopped.
  10. EV Family
    Georgia
    My X has finally stopped the squeaking as we approach 2000 miles in 2 weeks!
  11. goneskiian
    goneskiian Active Member
    Bellevue WA
    Now you just need that door to close! :eek::p;)
  12. svp6
    svp6 Member
    MN
    This was discussed many times with the S. Just brake hard few times. The noise will come back, but if you keep doing the same procedure it will eventually go away. More details here.
  13. Jeff McClure
    Jeff McClure Member
    Oak Park, CA
    Mine squeaked for a couple of months, but then stopped.
  14. Scrith
    Scrith Member
    Redwood City, CA
    Mine have been squeaking off and on for the first month, but it gradually seems to be happening less often (though my wife reported hearing them again this morning).
  15. MXadopter
    MXadopter Member
    New Orleans
    I have about 2000 miles on my X and there is a screech sound every time the car "rocks" at the stopping point. Forward or reverse any any speed, hard or soft braking. It is starting to make people ask if there is something wrong with the Model X. Not a good attention grabber for sure. A silent vehicle with a "screech" sound every time I stop. A
    Anyone else with the same sound when it "rocks" to a stop?
  16. Plan B
    Plan B Active Member
    EARTH
    Pretty much every Tesla that I have owned has done this.
  17. Jeff McClure
    Jeff McClure Member
    Oak Park, CA
    My breaks squeaked for a while, but went away after about 4,000 miles.
  18. systemcrashed
    systemcrashed Please Reboot
    I'm over 5,000 miles. Never squeaked.
  19. matdriver
    matdriver New Member
    Washington DC
    You have to change the regen from Standard to Low and put the on the brakes a few time (15-20) while driving and the squeak should go away. Then set the regen back to standard. This appears to be caused by a build up of brake dust or debris. One of the guys in Service told me to do this and it works for me every time they start to get noisy.
  20. Coolcarx
    Coolcarx Member
    nj
    Normal. The brakes do not get much work with regen. Hit the brakes hard a few times before you enter car line at school. No one wants to be the 100k+ car with squeaky breaks.
