DaveORD
Quick aside, what setting options do you have for regen? Is LOW still an option? Or have they removed that now? Thanks.637xx, amber signals front and rear. Picked up today, 11/5.
ah ha! thanks for clearing that up.After a certain VIN (not sure what #, but seems to be late-July builds) they include the correct/new 4-pin connector/wiring. The new connector works with old and new taillights (See post #101 ^)
Swapping the old taillights on today. What do you guys think the issue is?
From the picture, it looks like the harness can be plugged in two different ways? Did you try flipping it?I have a July build (28xxx) and have the 4 wire connectors. I installed the updated taillights, and they’re only half working.
- Amber turn signal works
- When brake: both C and amber light up
I still have 2 options - "Low" and "Standard". Not sure what cars are affected by any changes. I have 2020 MY LR running software build 2020.44. July build VIN 29XXX.That’s a software change and yes, low is gone.
Thx. Trying to understand how this will be applied, no definitive line in the sand yet.I still have 2 options - "Low" and "Standard". Not sure what cars are affected by any changes. I have 2020 MY LR running software build 2020.44. July build VIN 29XXX.
Damn.I tried flipping it, but upon further inspection, it can only go in one way. As a previous post stated, the connector needs to flip 180
You would need to have the car's configuration updated to know it has the new lights installed.
Ah! Is this done through the service center?
If they will do it for you. They might be able to do it remotely, I just don't know if they are willing. (They tend not to, like they wouldn't enable the new digital tuner that people installed in the MCU2 upgraded vehicles.)
Apparently true — see directly below.You would need to have the car's configuration updated to know it has the new lights installed.
I just got off the phone with Burlingame, CA Service Center. I explained the situation and he recommended I "submit through the app-- a tech advisor will reach out and can likely do it over air."
I hope hope this is the case. I'll keep you guys updated
VIN 32xxx, Late July build. I have Low and Standard, this article says that Low is gone only for cars that never had it -- starting with June builds: Tesla mysteriously removes regenerative braking strength option in new cars - ElectrekThx. Trying to understand how this will be applied, no definitive line in the sand yet.
Mobile tech made a visit yesterday and said that there is no taillight configuration that he could see but reloaded my firmware. No change -- the amber lights still illuminate with the outer C but they also blink like turn signals. Doesn't bother me at all.I just got off the phone with Burlingame, CA Service Center. I explained the situation and he recommended I "submit through the app-- a tech advisor will reach out and can likely do it over air."
Same. I just chatted with a Diagnostic Technician from Burlingame. Confirmed: If you have the 4 connectors AND your MY was built before mid August, currently there is no configuration change available that will allow the new taillights to function properly. According to the tech, this issue is fairly fresh so it's going to take some time to find a resolve-- if any. Based on the conversation I feel optimistic about it, so we'll see.
That gives me some up that this can work without a harness change and/or hack. Technically I can't see why it shouldn't be able to work as essentially you are running the old cars in euro tail light mode unless there's something I'm missing.
Did we ever figure out the purpose of the additional wire in the newer models?
Right. Not unless some electronics genius comes up with a module that can detect feeds from braking vs. turn signal (then split it into two outgoing wires for the new lights) which are currently fed through the same wire that lights up the LED bar. Seems doable but way above my pay grade.The additional wire is to separate the brake and turn signal lights.
I don't think that a car without the extra wire would ever light the amber portion of the lights.
