M
Photos please
"7 of 7 stalls available" seems like an odd number . . .but it is live on the car
I intended to, but when I only achieved 35kW it wasn't really worth taking that photo. I tried another stall. Same 35kW. I was at 75% SOC so I wouldn't get super fast speeds, but this is less than CHAdeMO. Maybe they will turn them up to full wick when they are comfortable they are working?Out of curiosity, could you also post a pic of the speeds you were getting? After all, this is a V3 Supercharger
The "pull through" stall sitting out by itself is the eighth stall, but it is not lit up and isn't energized."7 of 7 stalls available" seems like an odd number . . .
From your picture, red light...Ok. So it is open. There are 7of 8 pedestals working. I arrived with 90 miles remaining and have not seen V3 speeds. I started charging initially and it stopped itself. As I write this I have 193 miles and getting 105kW. I’m the only vehicle here. I have bounced around to see if any were faster that the others, but doesn’t seem to be the case. I have only supercharged one other time, so I don’t know if it’s normal or not, but I have heard at least 5 loud pops from the battery area below my feet. The car was preconditioned in route(25 min). View attachment 480226View attachment 480228View attachment 480229View attachment 480230
Educate me, please. What about their appearance tells you V3? I'd like to be able to spot these in the wild!Now those are what you call V3 cabinets!
I believe it's the vents at the top that most easily distinguish them from the v2 chargers which have vents at the bottom.Educate me, please. What about their appearance tells you V3? I'd like to be able to spot these in the wild!
From the manual: "If the charge port light turns red while charging, a fault is detected. Check the touchscreen for a message describing the fault. A fault can occur due to something as common as a power outage. If a power outage occurs, charging resumes automatically when power is restored."
Is that reduced speed because something is wrong with the car or the charger?
The cables I knew, but thanks. And thanks for the link!Of course the easiest way to tell is just to look at the supercharger cables which are much thinner on v3 stalls.
