c615586
I like having a perspective or 3d view on the dashboard map. I hope they don't remove this with the upgrade.
There is 3d or perspective view when you are away from intersection. When you come close to intersection it transfers to straight above view. If interested I can take pictures of bothI like having a perspective or 3d view on the dashboard map. I hope they don't remove this with the upgrade.
Exactly. Haven’t we seen this show before? Rollout with issues, followed by a slow buildup until they reach near parity with the 3rd party they were too cheap to continue paying.
Can’t wait.
Yes and in that show, many of the fanbois will already claim that it has reached parity or even exceeded, long before it reaches parity.
I don't think the map data is nearly that old. There are roads around me that have significantly changed in the last 6 months and they are displayed correctly on my nav.The current navigation system has a number of limitations, with very few improvements since it was introduced almost 6 years ago.
The navigation map data is loaded (at most) annually - a throwback to the early navigation systems which required visits to service centers to install new maps on optical disks or transferred to an internal harddrive. It appears the current US maps are at least 2 years old, and result in bad routing in areas with recent construction. To implement EAP/FSD, the navigation system must have up-to-date maps, which either means pushing map updates to the cars much more frequently OR (more likely) routing could be done on a cloud server (when it is reachable).
The speed limit data base is a mess. Tesla changed providers last summer - and the new speed limit data has many roads (at least in our area) that either have incorrect speed limits (too high or too low) or have no speed limit information at all on some roads [including frequently used side roads]. Since Tesla uses the speed limit data to restrict when EAP can operate in AutoSteer mode, we need more accurate speed limit data to avoid the rapid breaking that happens when driving on a highway and the software believes the speed limit has dropped below the EAP allowed speed. Like the map data, the speed limit data should be kept more up-to-date and may work better if the data can be pulled from a server rather than relying on sending out more frequent updates.
The navigation functionality is limited to the capabilities supported by the Navigon/Garmin software module Tesla licensed. Since that software supports functionality like waypoints or route customization on other platforms, either Tesla chose not to license that functionality, or (more likely) they decided not to implement the user interface for those features. Hopefully they are planning to do more than just replace the Navigon/Garmin software module with an alternative (open source?) replacement - and this time they'll plan to add features present in other navigation systems.
Google maps is currently being used on the console display - and because Google has invested a lot to keep their maps up-to-date, unless Tesla can find another source for similar quality, up-to-date, road and satellite map data, the new navigation software is likely going to continue using Google maps for the underlying map display - layering on top the navigation map data (routes, chargers, real-time traffic, ...).
Realistically, if we base the new navigation software on what we've seen in previous major Tesla software releases - it's likely to be a "two steps forward and one step back" release. There will be some new features/capabilities that will be great. The UI will probably look great. And there will be a few areas where we'll scratch our heads and wonder why anyone thought those aspects were ever a good idea (like removing the first letter scroll bars from the 8.0 media player UI).
Though with navigation map data and speed limit data so poor in areas right now - anything using up-to-date data has to be an improvement.
Bring it on!
Tesla vehicles in North America are using Navigon’s Q4 2015 maps, but the new modules are using 3 maps versions all dating from February to July 2017. That alone will be a welcomed change for Tesla owners.
Well, considering that there are new roads that are just months old on the current nav system, I question that statement.
On the speed limit database issue...
I had (perhaps laughably) assumed that the speed limit data came from the AP cameras seeing/reading speed limit signs and remembering the data -- basically building its own database. This assumption was based on the fact that my wife's AP1 Model S displays speed limit information, while my "classic" pre-AP Model S does not.
If in fact the speed limit information comes from a separate database, why is it not displayed in my pre-AP car?
My understanding is AP cars use the database, which is overridden by the camera data. So if the database says 60mph and the car 'sees' 50mph, the display will show 50mph.
As to why cars without cameras don't display database listings, my guess would be safety and likely regulations.
Without cameras, the incorrect info can't be updated. This would be especially bad in temporary speed changes such as construction zones.
I had (perhaps laughably) assumed that the speed limit data came from the AP cameras...
Incorrect, just because the wide-angle camera operates the wipers does not mean that is all it can do... Its neural net can be augments to recognize whatever else is needed beyond just rain/debris. In fact folks have seen that they were groundwork to do just that already beginning to be incorporated into the NN.No way to use the camera to read speed limit signs. They had to use that one to make the windshield wipers work.
So is Tesla doing away with Navigon completely?
Is the update a mix of firmware and a new map database? If the former, which firmware is required to run the new maps?
