New noise
Discussion in 'Model S' started by Steveb48, Dec 5, 2019.
  1. Steveb48
    Steveb48 Member
    San Jose Ca
    Hi All,
    Last night my car started making a noise like a fan with a bad bearing near the headlight on the passengers side.
    It doesn't mater if the AC is on, at least in the cabin. I'm trying to make a service appointment but the app just spins on
    "Getting Appointment Details".
    Any ideas on what the noise is and if it's safe to drive? Any ideas how to get the app to get past the spin?
    thanks,
    Steve
  2. whitex
    whitex Well-Known Member
    Seattle area, WA
    There is a fan there, you can get it fairly easily by popping the plastics around the frunk - I would check if anything got stuck in the fan. I once had a sticker fall off the wire harness fall into the fan and make a whole lot of noise.
  3. doghousePVD
    doghousePVD My grandfather’s car
    New England, USA
    The firmware increases the motor speed of the cooling system. The noise increased in my car, too, but the tech said it was normal. In very cold weather the equipment runs faster to keep the battery warm.
  4. PWlakewood
    PWlakewood Active Member
    US
    Careful, whenever a tech says this is normal it usually means:
    A: its normal
    B: I have no idea
    C: theres a bigger issue but I'm not gonna mention that to you and send you on your way and refer you back to A.
    If the fans are running faster it would cool the system not warm it up. When your hot do you turn your fan on to
    A: COOL down
    B: warm up
