Where is this on the app? If someone can tell me and let me have a referral code, I would be very grateful.
Oh no - maybe they will apply it for you or as I previously suggested, cancel and restart?Thanks, everyone. Unfortunately the "time limit" has expired after signing up.
Um, why wouldn't it be valid?Would anyone else like a referral code? I've just checked and mine is still valid.
Luke
It was that you couldn't use someone else's code retrospectively after a certain time. I'm pretty sure Octopus are very happy for all its customers to sign up as many more customers as possible; I'm waiting for the invite to a special commendation event for @Roy W.There seemed to be some comments above that they expire after some time?
Or have I got the wrong end of the stick.....
You’ll be the first on my invitation list!It was that you couldn't use someone else's code retrospectively after a certain time. I'm pretty sure Octopus are very happy for all its customers to sign up as many more customers as possible; I'm waiting for the invite to a special commendation event for @Roy W.![]()
(only kidding; well done Roy for being so quick off the mark!)
That’s first after @Mr Miserable of courseI'm hurt![]()
The smartgo tarrif from Octopus - off peak time from 00:30 to 04:30 - only 4 hours - not very helpful, should be something like 9 or 10pm upto 7am atleast. Any thoughts?Would anyone else like a referral code? I've just checked and mine is still valid.
Luke
It's been fine for us. In the unusual event more than 4 hours charging is required to charge to the target level set, but it's not actually needed, I set Teslafi to stop charging at 4:30.The smartgo tarrif from Octopus - off peak time from 00:30 to 04:30 - only 4 hours - not very helpful, should be something like 9 or 10pm upto 7am atleast. Any thoughts?
I’ve found that I’m able to add 60% of battery charge in 4 hours. As I set my max charge to 90%, I make sure I charge my M3 before the battery charge drops below 30%.The smartgo tarrif from Octopus - off peak time from 00:30 to 04:30 - only 4 hours - not very helpful, should be something like 9 or 10pm upto 7am atleast. Any thoughts?
You won’t find an off-peak period that long.The smartgo tarrif from Octopus - off peak time from 00:30 to 04:30 - only 4 hours - not very helpful, should be something like 9 or 10pm upto 7am atleast. Any thoughts?
Actually, you can, EDF offers exactly that, but as usual the devil is in the detail...
They give you a low rate from 9pm - 7pm Monday to Friday and all day Saturday and Sunday, sounds great doesn't it...
Well lets take a look at the actual charges, £0.08/kWh, but that's the 'low' rate, the normal day rate is £0.165/kWh and £0.29/day standing charge.
So yes, the headlines sound good, but unless you have very little usage between 7am-9pm Mon-Fri. the low rate isn't low enough to offset the higher charge, and even the low rate all weekend doesn't help that much as it really isn't all that low.
