New owner/ 2 questions
Discussion in 'Model S' started by Pestodude, Jul 6, 2014.
Tags:
  1. Pestodude
    Pestodude Member
    Los Angeles
    Sorry if these have been covered elsewhere but I did a quick search and didn't find:
    How do I stop navigation before I've reached destination. I've tried saying "stop navigation", "end navigation", etc but none of those commands work.
    Does applying the brake result in regenerative braking or add to the regenerative braking of simply taking your foot off the accelerator? IE: If I was coasting in neutral and applied the brake, would RB kick in?
  2. JVC
    JVC Member
    Cincinnati, OH
    In the NAV window on the touchscreen you can just tap "Cancel" to end Navigation.
    Applying the brake will still use a bit of RB. The strongest use of RB will happen when you take your foot off the accelerator but before you apply the brake. By pressing the brake pedal, the braking force is split between regenerative and the traditional brakes. Which results in a lower amount of regeneration. Watch the energy gauge on the right hand of the instrument cluster. The green bar will show how much regen is being used and when you apply the brake pedal you will see the amount of regen decrease and get closer to the 0 mark.
    Hope that helps! Enjoy your Model S!
  3. Jason S
    Jason S Model S Sig Perf (P85)
    Rocklin, CA
    The regen is based on the accelerator only. Applying brakes is just applying brakes. And I wouldn't fool around with neutral at speed, you can just keep accelerator at the right spot if you want to use zero power.
    Dunno about the voice commands. Try "cancel nav" perhaps?
  4. kvietor
    kvietor Model S S280 VIN 168
    Lithia, FL
    There is no voice command to cancel navigation.
  5. caddieo
    caddieo Member
    Palm Coast, FL
    +1. You significantly diminish your ability to control the car in unexpected situations. Try what a lot of TMC members do - educate and refine the movements of your right foot on the accelerator.
  6. jerry33
    Texas
    No. All of the regeneration is on the accelerator pedal. The effect of this is that there is no transition point between regenerative braking and friction braking the way there is in some other cars.
    1. Don't coast in neutral--there is absolutely no need to do this. (Check out the Wh/mi thread. My numbers are fairly low without resorting to coasting in neutral.) I don't want to hear that you're the next driver in a Tesla to run down a family in a Toyota. even if the chances of this happening are very low.
    2. Regenerative braking is dependent upon the motor being engaged. It's not engaged in neutral.
  7. Pestodude
    Pestodude Member
    Los Angeles
    Thanks for your replays (Although JVC said that pressing the brake pedal DOES produce some RG and others said it produces none). Guess I'll go with the majority on this.
    BTW, I didn't plan to brake in neutral as a practice. I was clarifying my question...IE: If the accelerator is not a factor at all (car is in neutral), would applying the brake produce any RG?
  8. NoMoGas
    NoMoGas Member
    Los Angeles, California, United States
    no.
  9. ggr
    ggr Roadster R80 537, SigS P85 29
    San Diego, CA
    I think you misread what he said. Anyway, the brake is only a brake, and the other pedal entirely controls regeneration when you're in gear, in either direction.
