Hey all,
I had a post about needing my driveunit (inverter, side mounts, the whole shebang 2014 P85) replaced last week since it died on me in the middle of a busy road. Looking through the part numbers it appears I got the P revision drive unit so I was pumped (not an old refurbished one). However when I got the car, I noticed right away that the throttle response was not the same and it almost felt like the car was driving through mud, just slower than before. With my previous driveunit, the rear end would wiggle under heavy acceleration but barely at all now.
Thinking that it could all be in my head, I downloaded the Powertools app to see what my max KWh were and to try to do some 0-60 tests. Just flooring it around going from 30-70 etc, I would max out at 319 and then I was able to do a couple of 0-60 runs at about 75% Soc. First run was slightly up hill and I got 4.8 seconds and the second was flat and I got 4.2 seconds. Max KWh was 322. So while technically within spec at 4.2 it still feels way slower. I have read about others getting into the 350s in KWh in their P85. What have you all with a P85 seen? I am wondering if any of you with the revision P Driveunit have run the same test compared to your previous driveunit.
My thought is that Tesla found a way to make the new drive unit's stronger but at the same time are limiting the power versus before to keep them technically in spec but still slower in general to last longer. No more 3.9 sec 0-60...
